Improving handling
Stickier tires? My Nittos are pretty good, they grip real well..what would you recommend for the tires? I want to cut body roll as much as i can, what can i do about that
He is asking for 2 things
A stiffer setup, but he still wants ride comfort.
I think you will feel a difference with the sways. but not that much.
If you really wanted a total different feeling, you would need to lower it a tad bit and get stiffer suspension and the under body brace.
But you will loose a tad bit of your comfortable ride.
You are asking for half of the shirt starched in one line, then asking for the entire shirt to be starched next.
You cant have both.
You cant have both.
So, to expand my thread here.....
Assuming I did not want to lower the car, would adding stiffer shocks on the stock 250 springs do anything noticable? Are the shocks stiff enough by themselves. For this question eliminate the concern about ride quality.
You cant have both.
You cant have both.
I think its the 40 or the 45, whatever the stock tire size is. I didnt change any of the sizes i just replaced them with nitto invos
basically here's what you do to eliminate body roll.
A) F-Sport Sway Bars Front and Back.
B) Adjustable Coilover Suspension (Corner weight the car)
C) Tom's Underbody Brace kit
Optional) Just for fun, throw in that Jun-TW Strut Tower Brace
I'm on F-Sport springs on stock shocks. I also have the F-Sport rear brace and sways. Handling has improved a lot over stock. My next plan is to install coils (of course I'd have to sacrifice a little on the ride comfort) and hopefully handling (and looks ) can be improved even more.
Thanks alot for all your help guys. I'm really considering coilovers bcuz of my driver side being alot lower than the passenger side, its really freaking annoying and the only fix is coilovers :/
see what i mean?
see what i mean?
