IS350 (brake) Upgrade on IS250
Old 10-22-14, 03:02 AM
  #31
Boomin
Boomin's Avatar
Soooooo, 60-0 feet comparisons ? I know I read 250f-sport is 115'
Old 10-29-14, 01:33 PM
  #32
FSportIS
FSportIS's Avatar
What drilled/slotted rotors are you guys running? They look very nice lol.
Old 11-07-14, 06:42 PM
  #33
Ants350
Ants350's Avatar
I used stop tech.
Old 07-20-15, 03:32 PM
  #34
Bryan858
Bryan858's Avatar
Default Hardware?
Hi all, what is the hardware kit refered to in the first post? I have my Calipers, brake pads clips. Waiting on a rebuild kit and rotors. Do the is250 caliper mounting bolts bolt directly to the is350 calipers or do I need to buy is350 mounting bolts? I plan to cut and bend the dust shield and save a few bucks as well. Just want to be sure I have all I need.
Old 07-20-15, 07:01 PM
  #35
knguyenk
knguyenk's Avatar
Yes, the bolts that were used to hold the caliper to the knuckle are the same so reuse them as well as the banjo bolt that supplies the brake fluid to the caliper from the brake line.
Old 07-21-15, 09:56 AM
  #36
Bryan858
Bryan858's Avatar
Perfect, Thanks!!!
Old 07-21-15, 05:02 PM
  #37
nyis250
nyis250's Avatar
Does anyone have issue rebuilding the calipers? I'm currently stuck on sitting the dust boot on the caliper and pistons. What method did you guys use?
Old 07-22-15, 05:37 AM
  #38
knguyenk
knguyenk's Avatar
I used the grease that they supplied in the rebuild kit and greased the dust boot up with a thin coat and worked the dust boot around groove of the piston and the lip of the caliper that surrounds the piston.
For the part of the boot that goes around the part of the caliper, start at one side and just work it around until you hit the end and then it should seat itself (as long as the boot was greased); otherwise, you risk tearing it.
Old 07-27-15, 07:25 AM
  #39
nyis250
nyis250's Avatar
I used the grease as well but I cant get the boot to situate in the caliper as I press the pistons into the caliper.
I find the space between the piston and the caliper too small to fit the boot.
Currently I have the boot placed on the piston first and then fit the other end of the boot into the groove of the caliper. As I press down on the piston, the end of the boot inside the caliper retracts out.
Or should the boot go on the outside silver ring?
Old 01-22-16, 09:43 PM
  #40
Markcma3
Markcma3's Avatar
Has anyone seen this done on a 2014 IS250? If so please post info.
Old 02-16-16, 04:39 PM
  #41
DmcL325i
DmcL325i's Avatar
anyone confirm that it is the same discs and calipers used on the GS300 as on the IS350?
wanting to know as we didn't get the is350 in Europe and nearer time to replace my front discs/pads id like to upgrade to the larger discs and calipers. if its the same stuff on the GS I can just hunt down what I need from a GS... otherwise I'm into shipping from the US.
Old 02-16-16, 05:33 PM
  #42
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Yes the European 2006-2015 GS300, 350, 430, 450h and 460 all had the same brake calipers as the IS350 (excluding 2012+ RWD GS models with the F-Sport package and larger brakes).
Jeff
DmcL325i (04-23-17)
Old 07-05-16, 08:40 AM
  #43
rohanstar
rohanstar's Avatar
Default two bolts from 250 caliper
the 2 two bolts that bolt on the 250 calipers are they the same bolts use to bolt on the 350 calipers ?
Old 07-05-16, 10:28 AM
  #44
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Yes, they are.
Jeff
Old 11-02-16, 04:58 PM
  #45
Ling2IS
Ling2IS's Avatar
Do front 250 rotors work with 350 calipers?
Any photos on how to separate the caliper from the brake line?
Quick Reply: IS350 (brake) Upgrade on IS250
