Rubbing Issues after new set up.
I'm currently lowered on Tein CS version 1 with Exact front RCA's. I'm slightly tucked in the front with 19x8.5 24offset. I believe my tires are 245/35/19, but I could be wrong. The tires are slightly stretched and my fenders have been rolled.
I like my stance, but I'm rubbing when I hit a small bump on the road. This occurs even when I'm driving straight. I believe my issue might be the inside mud guards, but I'm not exactly sure.
Any ideas?
Should I remove the inside mud guards? Will it be safe?
Should I just raise the front?
Thanks for your help everyone!
Any ideas?
first, i am amazed that you're even rubbing on CS with an 8.5 and a 245/35 combination. Second, exactly like spyder said, 245 on an 8.5 is nowhere near stretched...as a matter of fact thats a recommended standard size for an 8.5. If removing the inner guards doesnt work, you'll have to try a 225 on the fronts. Again i'm amazed you're rubbing at all with CS. Are you sure the a/r is 35 for your tires? If it's a 245/40 then there's your problem, go to a 35. But if youre rubbing on a 35 something is outta wack.
I'm going to do the heat gun and bat trick. I took the car out the other night and when I'm driving by myself, the car is fine. When I have a friend a passenger, the tires rubs with every little bump on the road.
I think the tire size I listed is incorrect as well. I think the tires up front might be wider.
It's raining in CA right now, I'll probably work on it next week. This should solve the problem. Thanks everyone for your help. I'll keep everyone updated.
