F-sport Sway Bar Intall on an 09 is250! Just a bit Different
Old 02-07-09 | 01:47 PM
ocbc's Avatar
ocbc
Default F-sport Sway Bar Intall on an 09 is250! Just a bit Different
OK I took the 250 to my buddy with a LIFT to do this job. All expectations were a quick and easy install. The front went on with out a problem.
Front stock set-up:
Comparo picture of the two bars:
Front F-Sport Install:
I had to remove the ball joints and flip the left and right to get the set-up to work:
No for the rear. Apparently there was a change in 2009. The rear sway bar bushing is sandwiched between 2 aluminum plates. Not only is it sandwiched, it is perminantly glued in:
I had to cut out the rubber bushing and then grind out the leftovers.... I was not too happy about this.
Now the new bushing into the:
Comparo of the two bars:
Installed:
The set-up works, I am definitely going to check to see if I can get the older bracket to bolt up. I think I would feel batter about it. There was no bracket listed on the parts order, or else I would have waited to pick it up.
I have not driven it much as it is raining here in So cal. Ill test it out this week. The suspension does feel stiffer if you will. Body roll is not completely eliminated.
Old 02-07-09 | 11:20 PM
Joe Z's Avatar
Joe Z
Great Pics & info...
That's an interesting change done to the rear 2009 IS250 sway bar bracket.. !
Joe Z
Old 02-09-09 | 01:03 PM
conan7's Avatar
conan7
Thanks for the info. I'm thinking of installing it on my new IS 250 too.
Where did you order the sway bars? Did it come with the new bushings for your rear bar?
Old 02-09-09 | 02:36 PM
t0e's Avatar
t0e
The sway bars should have come with Both Front and Rear, new bushings.
FAQ material...
Old 02-10-09 | 05:40 AM
omgswifty's Avatar
omgswifty
hrm.. let us know when u've driven the car around. i'm still deciding on getting the rear sways =/
Old 02-10-09 | 07:06 AM
Kurtz's Avatar
Kurtz
Just do it.
I've yet to own/drive a car where a good sway bar upgrade wasn't the best/easiest/cheapest improvement you could make to the vehicles handling.
Old 02-10-09 | 10:05 AM
ocbc's Avatar
ocbc
The sways work great. deffinitely feel it in the turns. After some time spent driving it, i can tell that they are there lending a helping hand! =)
AS it turns out, there is a new kit for the 2009 models. I was not aware of this when I ordered my set. the company I purchased from is working with me right now on it. Ill let you know how it turns out.
Old 02-10-09 | 11:31 AM
conan7's Avatar
conan7
Great Please let us know.
I can't wait to install it with the Tein S-tech springs.
Old 02-13-09 | 02:18 AM
LXIGRL's Avatar
LXIGRL
Which company is that ?
Old 02-22-09 | 10:29 PM
Nellyhx's Avatar
Nellyhx
I have these on my 08 IS350 and they eliminate some body roll but not all. I feel alot safer around corners with the F-sport sway bars than the stock ones. For those who have driven on the end of the 110 freeway towards Pasadena where it's really curvy, I can take the turns going around 100 mph without having the fear of body roll or loss of control. It's a great upgrade and I can't imagine driving this car without it again.
Old 02-22-09 | 11:08 PM
Joe Z's Avatar
Joe Z
Lightbulb
My favorite part of leaving work.... the 110 Pasedena drive home...
Old 02-25-09 | 09:57 PM
ohno's Avatar
ohno
So is their a night and day difference or just a minor one?
Old 02-25-09 | 10:54 PM
darkdream's Avatar
darkdream
I can't speak for IS250s, but on a IS350 it is a night and day difference.
Old 02-26-09 | 09:21 AM
Nellyhx's Avatar
Nellyhx
I don't think it's a Night and Day difference, maybe a night and morning difference
Old 02-26-09 | 12:32 PM
radicalrev's Avatar
radicalrev
lol...isnt the road small??
Quick Reply: F-sport Sway Bar Intall on an 09 is250! Just a bit Different
