Correcting the suspension geometry.
Master Thread Closer!!
My new coilovers allows for 2 ways to lower the car....either compress the springs (like above) or adjust the bottom mounting tube. I chose the latter. By adjusting the bottom mounting tube...I leave the spring and shock travel untouched....as it was intended by the manufacturer.
Btw...I was still able to slam it down...actually, my car was sitting on my tires (need to shave fenders)....LMAO!!!
Note, I am on 20s...with RCAs, but I still had alot of threads to lower even more.
CK6speed can verify this.
Pete
I really could care less about putting my suspension geometry within factory spec but I want my alignment to be close to it. I'm running -2.6 of camber now and seeing the inside of the tires wear makes me worry when I think that I only have that much contact patch instead of using the entire width of the wheel (toe and caster are within factory spec).
As for shock travel, I don't see why I would want to limit the travel of a suspension...if a shock is meant to move, why limit it? I'm a suspension noob so just curious. Feel free to shed me some light here.
Alexus 300, when you say a 2" drop would not prevent you from adjusting back to factory, do you mean the toe? or camber also? I dropped my gs on Tein SS and its as high as it will go (about 1.25 to 1.5") and it is well beyond factory spec. Maybe the shop I took it to don't know shat.
What I meant is that with the height given in prior post, you can still utilize your factory alignment spec. While I have no experience with Tein SS, I just hate the way that they are engineered. It's the worst engineering design that I've seen in a while because of cost reason. With the Tein SS, in order to change your ride height, you're gonna have to change your spring load. This is bad because when you are trying to lower your car, you're actually compressing the spring load beyond what they are designed for. When this happens, you have less shock travel which results in blown shocks overtime which I've heard alot of people with Tein coilover experiencing. What you want in a coilover is for the shock to have full travel so that it can utilize it's compression and rebound design. I'm not sure if you get what I'm saying as it's alot to digest..
Think about it. How many coilovers manufacturers have a dedicated page on their website....entirely for re-building / overhauling their coilovers? Clearly bad engineering/design.
But they have a great marketing dept...made us buy them, right?
Im back up again...about 1 finger gap.
Lexus082
Suspension and Brakes
11-23-07 12:32 AM
