Finally did my ls400 brake upgrade!
Old 02-10-09, 01:41 PM
sck_GS300
sck_GS300's Avatar
Default Finally did my ls400 brake upgrade!
now i have one question, is there any way that i can upgrade the rear calipers to better ones? someone please help
Old 02-10-09, 02:26 PM
Vincent123
Vincent123's Avatar
if i may ask, how much did this whole conversion cost you?
Old 02-10-09, 04:54 PM
Kyle Harty
Kyle Harty's Avatar
Did you use RCA's or shave the bolt and caliper? If you shaved, I'd be interested to see pics of exactly what/how much you had to shave off.
Old 02-10-09, 06:33 PM
PHML
Master Thread Closer!!
PHML's Avatar
Old 02-10-09, 07:52 PM
FinLIFE
FinLIFE's Avatar
no need to upgrade the rears imo, I think they are already 2 piston and only other option is aftermarket bbk which means fronts have to be done as well or go with supra rears, but they seem to just be a bulkier 2 piston caliper.
Old 02-10-09, 08:57 PM
evil00017
evil00017's Avatar
Hows the stoping improvement with the ls400 brakes?
Old 02-10-09, 10:06 PM
99Aristo
99Aristo's Avatar
eh, GS's are single pot and you canus the Supra dual pot ones but like you said, not really worth it. I'd like to see the LS400 caliper pics myself as I have been threatening to buy some for awhile. I found a site to buy them for about $220 shipped also including the core charge.
Old 02-10-09, 11:53 PM
sam430
sam430's Avatar
Or you can just go to napa autoparts and pick one up and return the core there. Check the GS first gen section for picture. Looks like part of the crown were cut off. I suggest you fully seat the bolt and mark which crown to cut off. Then remove it and cut the crown and shave off some thread...or put 1/2 inch metal washer, where RCA block would go, to reduce how much thread to cut off. Don't go overboard with them metal washers...the circular seats needs to go into the other section to prevent play. make sure the metal washer fit the sleeve (may have to sand the inner metal washer to make it fit the sleeve).
Sorry not too description...just put one and one together.
Disclaimer...do at your own risk. May cause injury or even death. There.
Old 02-11-09, 12:11 AM
milky
milky's Avatar
You should pm Gsteg, he might still have a set or two available. Usually runs around $200 or so for the calipers, then you'll need to get some bigger rotors, pads if you'd like, and maybe stainless steel lines as well.
Old 02-11-09, 06:39 AM
ElitistK
ElitistK's Avatar
incorrect. the 2gs rear caliper is a 2-pot setup; a pot on the inside and another pot on the outside.
Old 02-11-09, 10:23 AM
sakataj
sakataj's Avatar
for once we agree elitistk
Old 02-11-09, 12:16 PM
sck_GS300
sck_GS300's Avatar
Default brakes
Iill post pics up soon im at work and dont have access.
Old 02-11-09, 01:33 PM
sam430
sam430's Avatar
Do you guys know if the 3GS and 2GS brakes are interchangeable? Sorry, didn't search...it's just that the GS-F is coming.
Old 02-12-09, 10:12 AM
sakataj
sakataj's Avatar
yeah in 3 years
Old 02-12-09, 10:28 AM
sam430
sam430's Avatar
Originally Posted by sakataj
yeah in 3 years
debut in 2010? it better have engine upgrade.
Quick Reply: Finally did my ls400 brake upgrade!
