DIY: IS250 front brakes
Great write up.
My only suggestion is to replace the C-clamp w/ a special tool designed to compress the piston on the caliper. This is a cheap version and should cost under $10.
The only reason I suggest this is that it puts even pressure on the entire piston by placing the compression point at the center rather than just one side.
On further inspection of your photos you could accomplish the same effect by reversing the C-clamp and placing the point at the center of the piston rather than the edge. Assuming of course there is clearance for the C-clamp to attach this way.
Like I said earlier, you can just leave the brakpad that is on the piston side and use the clamp...no need to find the tool or buy one! But I agree about the uneven pressure thing...
Thanks for posting the pic.
You should "turn" the rotors whenever the brake pads are changed. You should be able to take them to any Auto Zone type store to have them turned. Cost is about $20-$25. They also must be within a thickness tolerance spec. or they will not turn them and you will have to replace them. It you do not turn them and they are worn the new brake pads will not last as long an my not perform as designed and specified. I have replaced brake pads w/o turning the rotors on one vehicle once and did not experience any problems. My pads were changed @ 5000 miles on my IS two weeks ago. I assume that due to the low milaege Lexus did not turn the rotors.
Links to IS350 Brake Pad Change:
Front:
https://www.clublexus.com/forums/sus...g-caliper.html
Rear:
https://www.clublexus.com/forums/is-...-stickers.html
Front:
Rear:
...You should "turn" the rotors whenever the brake pads are changed. You should be able to take them to any Auto Zone type store to have them turned. Cost is about $20-$25. They also must be within a thickness tolerance spec. or they will not turn them and you will have to replace them. It you do not turn them and they are worn the new brake pads will not last as long an my not perform as designed and specified. I have replaced brake pads w/o turning the rotors on one vehicle once and did not experience any problems. My pads were changed @ 5000 miles on my IS two weeks ago. I assume that due to the low milaege Lexus did not turn the rotors.
Javier
Nice write up Javy!
