DIY: IS250 front brakes
#31
kinda new on replacing pads, so after its all said and done will the piston go back to its normal position or do you need to apply preasure and or maybe bleed the brakes, please help
#32
http://www.dreamstime.com/channel-lo...umb7404047.jpg
And then squeeeze the F out of it using the old pad and the caliper itself with a rag over it..don't worry you won't damage anything
#36
The brake pedal should NEVER go down to the floor, EVER. That happens when there is air in the system or when the brakes are overheated..
#42
Great writeup, and awesome pics...Thank you,
Few questions:
Can someone help explain why the brake rotor require grinding / resurfacing? I know it's from uneven wear, but what exactly causes this to occur? I guess you cant do brakes at home if this has occurred.
Also, I remember leaving the old brake pad in the caliper while using the C-clamp to push the piston back down, as I was told it could damage the piston from uneven pressure if pressed directly...(I figured the guy was being too picky, considering the caliper experiences extreme amounts of heat and pressure while in use, I am sure it could handle a little C-clamp pressure). Your thoughts would be great...
Few questions:
Uneven wear can be caused by excessive heat and/or sudden excessive pressure on the rotors (slamming on the brake pedal in an emergency, for example).
For front brakes, you're better off putting new rotors in anyway when you do the pads, unless the pads wore out extremely prematurely, like within 10-15k miles. It might add $100 to the total cost of the job, but the car will perform better, especially since a large percentage of the actual braking is done by the front pads/rotors. Thinner rotors get heat saturated faster, and will transfer more heat to the entire braking system. Boiling the brake fluid is what causes brake failure, so you want to keep temperatures from reaching extreme highs very often. Also the higher temps will make the thinner rotors more prone to warping/grooving. If it were the rears, I would say use em until they wear out...
You are correct about using the old pad with the C-clamp, you don't want to exert pressure on just that one part of the caliper piston, it's better to spread it out. From the pics it looks like the piston is "hollow", so you don't want that edge to bend...
#43
Tech Info Resource
I haven't found a brake piston I couldn't press in by hand. If it takes more force than your hand can generate you need to get to the gym or replace a bad caliper.
Fluid boiling is only one failure mode. Pads can fade.
Rotors add $100 to the job? More like $300 just for the fronts on the 350, unless you're going aftermarket.
#45
first i wanna thank the OP for this DIY. i had a lot of fun doing this job and it saved me $200.
my question is, i didn't have a shim kit but i put the anti squeal grease on the back of the pad which comes in contact with the caliper and piston. did i just screw something up? should i wipe it off and install the shim kit?
