Camber wear...solutions?
"right" as in right for your suspension. There is no magical number, which is why you need to bring your car to someone who actually knows what the hell he/she is doing.
Having "OEM spec" is not good enough. OEM specs are just for that..OEM suspensions. Just because your static camber and toe are matches stock specs, doesn't mean they'll be the same dynamically.
Darrin at WestEnd is known as one of the best guy for the job. It's a privilege to even let him touch your car. Too bad he's in Socal because we need more guys like him.
Since I live over 3000 miles from this guy, there's not much chance he'll ever touch my car.
What's the full name of the shop at which he works? It sounds like it's worth a call to pick his brain and find out his formula for setting toe.
Clearly, "within spec" is useless. It's such a broad range it's laughable.
