Rack and pinon quest?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
if your system is low on fluid the rack doesnt go bad. it will always have some fluid in it and wont wear out due to that reason. working at a shop strictly specializing on toyota/lexus cars i have never had to change a rack on an SC. i worked there for 3 years on and off. power steering pump yes but not the rack. what makes you think the rack itself is bad? if you are low on fluid the bearings in the pump can go bad and make noise.
of course the rack can go bad after time but i havent seen one. good luck
