Just a reminder to all who perform this method. Do not leave the pump running more than 10-15 sec. each time or else, it'll be one expensive brake job since your ABS pump motor might get burn.
You mean during extraction of the fluid right? because it doesn't make sense because I step on the brake way longer at the stop light. Just clarifying.
also, the resevoir will get empty if done too long.
Yes, sorry that I didn't clarify. But make sure not to drain out your resevior when flushing out the fluid since the pump gets hot.
