swaybar questions
Old 02-16-09, 02:11 PM
hung8852
hung8852's Avatar
Default swaybar questions
is the is350 rear swaybar the same as the awd version? I just want to get the rear one...saw one for sale, but its for is250awd. thanks in advance!
Old 02-16-09, 08:47 PM
Foodplz
Foodplz's Avatar
yes it is the same.
Old 02-17-09, 06:08 AM
hung8852
hung8852's Avatar
sweet thanks.
Old 02-19-09, 05:46 AM
Keith13b
Keith13b's Avatar
Originally Posted by Foodplz
yes it is the same.
You might want to double check that! The shape is different and I believe the diameters are different as well; similar in performance, but different in size. The 350's bar will be a little stiffer. Not noticable or worth the upgrade unless you are swapping out the front as well. In that case you should change the rear to keep the matched set.
Old 02-19-09, 01:43 PM
kayotik
kayotik's Avatar
The rear F-SPORT sway bar for the AWD will fit both 350 and 250 RWD models. It is the same bar that comes with the full package.
Old 02-19-09, 06:45 PM
ISF4life
ISF4life's Avatar
its the same i just installed mine today , i ordered AWD 250 to install mine check out the pix in sway bar thread :P
Old 02-24-09, 09:39 PM
KML505
KML505's Avatar
Default Rear Sway for ISF
do you guys know if the IS350 rear sway bar is the same as the ISF one? If not, what is the difference in the diameter?
Old 03-13-09, 09:54 AM
flowrider
flowrider's Avatar
Received 1,920 Likes on 1,355 Posts
^^^^ The stock rear sway dimensions for the IS rear sway bars are as follows:
250AWD - 14mm
250-350 - 15mm
ISF - 17mm
F-Sport:
250AWD - 17.5mm
250/350 - 19mm
Lou
Old 03-13-09, 10:10 AM
kayotik
kayotik's Avatar
the 250AWD and 250/350RWD F-Sport REAR sway bar should be the same....
Old 03-13-09, 10:12 AM
Kurtz
Kurtz's Avatar
According to another recent thread (which had a PDF from lexus attached) that changed last month.
They issued a new set of rear AND front bars for the AWD model that are different from the RWD ones.
Old 03-13-09, 10:22 AM
kayotik
kayotik's Avatar
oh, for the 09s?
Old 03-13-09, 10:49 AM
flowrider
flowrider's Avatar
oh, for the 09s?
No - For all. See attached.
Lou
File Type: pdf
Old 03-13-09, 11:10 AM
kayotik
kayotik's Avatar
I was talking about the rear sway bar for AWD before this new set. Is it the same bar as in the new set?
I've always received confirmation from Lexus dealer's that the AWD rear only was the same as for the RWD models.
Oh well, better for the AWD guys
Old 03-13-09, 12:10 PM
flowrider
flowrider's Avatar
Prior to the new set, the bar for the AWD IS was indeed the rear same bar used in the RWD set. The rear bar in the new set is something different (17.5mm vs 19mm). I have the 19mm rear bar installed in my F.
Lou
Old 03-13-09, 01:13 PM
kayotik
kayotik's Avatar
I thought so. Thanks for the confirm.
Quick Reply: swaybar questions
