Alignment Specs wanted for 98 GS300
I am sure there must be a thread somewhere for this, but could someone please post or email me alignment specs for my car. Is it a 2 or 4 wheel alignment?
Thank you!
Cary in South Dakota
Thank you!
Hope this helps...
Front
Vehicle Height:
P215/60R16:
Front* 243 mm (9.63 inch)
Rear** 226 mm (8.90 inch)
P225/55R16:
Front* 240 mm (9.45 inch)
Rear** 221 mm (8.70 inch)
P235/45ZR17:
Front* 238 mm (9.37 inch)
Rear** 219 mm (8.62 inch)
Camber -0°16' ±30' (-0.27°±0.5°)
Left-Right Error 30' (0.5°) Or Less
Caster 7°33' ±30' (7.55°±0.5°)
Steering Axis Inclination 8°52' ±30' (8.87°±0.5°)
Toe-In:
Total: 0°09' ±12' (0.15°±0.2°),1.5 ±2 mm (0.06 ±0.08 inch)
Rack End Length Difference 1.5 mm (0.059 inch) Or Less
Wheel Angle:
Inside Wheel:
Degrees In Minutes 38°51' (36°51'-39°51')
Degrees In Decimals 38.85°(36.85°-39.85°)
Outside Wheel (Reference):
Degrees In Minutes 32°05'
Degrees In Decimals 32.08°
* Measure From The Ground To The Center Of The Lower Suspension Arm Mounting Bolt.
** Measure From The Ground To The Center Of The No.2 Lower Suspension Arm Mounting Bolt.
Rear
Vehicle Height:
P215/60R16:
P225/55R16:
P235/45ZR17:
Camber -0°47' ±30' (-0.78°±0.5°)
Toe-In:
Total: 0°08' ±12' (0.13°±0.2°),1.4 ±2 mm (0.056 ±0.08 inch)
Link And Arm Length Difference 4.0 mm (0.16 inch) Or Less
Front
Vehicle Height:
P215/60R16:
P225/55R16:
P235/45ZR17:
Toe-In:
Wheel Angle:
Inside Wheel:
Rear
Vehicle Height:
P215/60R16:
P225/55R16:
P235/45ZR17:
Toe-In:
