Hawk HPS Brakes
Old 02-28-09 | 07:36 PM
NYGSDriver's Avatar
NYGSDriver
Default Hawk HPS Brakes
Hello all, I am newbie here, to ask a few brake questions. I have a 99 GS300
I was unhappy with my brakes for a long time So I went and bought
front and rear Hawk HPS brake pads, the rest of the brake setup is stock.
I went to local mechanic/speedshop guy and had them installed. When I
got the car back I noticed that the braking only feels slightly better and
now my foot can literally go down to the floor, I did not have this before.
I went back to the shop and had the mechanic bleed the brakes, that
really did not help at all, the rotors are fairly new lexus rotors.
Thanks for any help
Old 02-28-09 | 07:59 PM
GSteg's Avatar
GSteg
Was the key in the Ignition position when they bled the brakes?
Old 02-28-09 | 08:12 PM
NYGSDriver's Avatar
NYGSDriver
I will check on monday, why is that important?
Old 02-28-09 | 11:07 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
Yes since in order to bleed the brake the car has to be on since the brake pump is electric
Old 02-28-09 | 11:29 PM
NYGSDriver's Avatar
NYGSDriver
ok, what do you think of my other issues?
Old 03-01-09 | 12:32 AM
Spyder78's Avatar
Spyder78
CL Folding 25,000
What other issues? I see the only issue posted is that your brake pedal goes down to the floor. That means that there is air in the lines and they need to be bled. The proper procedure to bleed the brakes on the GS is to have the key in the on position and than do bleeding as usual.
Old 03-01-09 | 12:36 AM
CK6Speed's Avatar
CK6Speed
Ah, thanks for that info on having the key on. I would not have known that myself. Now, when I do my brakes I'll be sure to turn the key on.
Old 03-01-09 | 12:42 AM
GSteg's Avatar
GSteg
You turn the key to the on position to cycle the brake booster. It's a way of bleeding it, unless you get your hands on the handheld Toyota Techstream.
Once you're done with the rear, turn on your engine and run it for a min or so. If you try to bleed all 4 corners with the key in the ignition, your battery may die, at least mine did. With the pump running all the time, your battery may be taking a beating.
Old 03-01-09 | 01:42 AM
Spyder78's Avatar
Spyder78
CL Folding 25,000
I have the yellow top didnt kill it and let me do all four sides but good info Gsteg.
Old 03-01-09 | 02:04 PM
NYGSDriver's Avatar
NYGSDriver
Thanks for the replys, I spoke to the mechanic this afternoon, he said he had done
all of the above correctly. So here is the main problem. Should my brake pedal ever
hit the flood, when I stand on it? Also I am feeling very little difference in brake
(feel) with these Hawks over the stock brakes...
Old 03-01-09 | 03:18 PM
Alexus_300's Avatar
Alexus_300
My first advice would be to let your ABS pump cycle through the fluid for around 30 sec. Then start the car and bleed the brakes making sure that there is always fluid in the resevior. Check to make sure that none of your brake lines are cracked or damage. If you want to be safe, get Stainless steel lines for around $150 for all four corners. Another thing to look out for is if you notice that the actuator pump is working non stop when bleeding, turn the car off and let it rest after the pump has been running for around 5 mins. for cool down or else you're gonna burn up the pump. Also, hawk hps pads are crap. If you are using a pad that is that aggressive, look into Carbotech or performance friction pads. Those are good pads that can be used on daily street driven car and track as well.
Old 03-01-09 | 04:27 PM
vwynn's Avatar
vwynn
are OEM pads good? or wats the "best" to get for just regular DD driving with the occasional spirted drive.
Old 03-01-09 | 05:14 PM
GSteg's Avatar
GSteg
OEM and spirited driving? Never heard those two words go hand in hand before
I'd go with Akebono ProACT ceramics before going back to OEM. I had these when I had my OEM GS calipers and they were great. Brake dust were light gray in color, and they didn't seem to nearly fade as much as OEM. Plus they're $10-20 more only.
Old 03-01-09 | 05:41 PM
vwynn's Avatar
vwynn
ok so i just called up Kragen regarding brake pads.. they have 1 set in stock for $30.99? Ceramic.. i think its called Best Brakes??
wondering should i go get it? i really need new pads since the indicator is eating the rotor.
Old 03-01-09 | 05:53 PM
GSteg's Avatar
GSteg
I think I rather go OEM than Best Brakes. heh.
Take a look at your pads right now. If they still have material, and the only thing that is rubbing is the wear indicator, just bend, get rid of the indicator tab in the meantime. It should hold you in until you get the pads you want.
