Race brakes lots of questions???
No one has concrete numbers because the weight varies from one brand to another. The Supra rotors are only lighter if they're the aftermarket version with aluminum center hub. I dont recall seeing one for the LS.
But OEM LS vs OEM TT, the weight difference is negligible on a car like the SC.
weights
i found this online
LS400:
caliper weight - 9 lbs
rotor diameter - 12.4 inches
rotor thickness - 1.26 inches
Supra:
caliper weight - 15 lbs
rotor diameter - 12.72 inches
Personally...I'm not sure whether to trust the accuracy of the weights given. From the pictures...they both look like they are sized very similar (both are 4 piston calipers). The rotor diameters are close, and the thickness is the same. So I find it a little difficult to believe that there is a 6lb difference in weight. Not saying that this can't happen...but I'm not sure if I trust the info.
LS400:
Supra:
weights
"OEM Lexus SC400 Brake Specifications caliper 2 piston 17.5 lbs. rotor 11.65 inch 20 lbs. rotor thickness 1.26 inch
OEM 95-00 LS400 Brake Upgrade ($300 to $500) caliper4 piston 9 lbs.rotor 12.4 inch, dk lbs. rotor thickness 1.26 inch
OEM 93-98 Supra Turbo Brake Upgrade ($500 to $1000) caliper 4 piston 15 lbs. rotor 12.72 inch 20 lbs. rotor thickness 1.26 inch"
FOUND THIS ON CL
FOUND THIS ON CL
jeff1941
Wheels, Tires & Brakes Forum
02-27-08 05:00 PM
