What do you guys think (about spacers)?
i have a few questions regarding spacers and the is350 calipers.
Spacers.....I'm tryin to get the rims as flush as i can w/ the car's fenders, now i have the stock rims, stock tire size (staggard from the dealer) I believe the fronts are 225 and the rears are 255s. What size would you guys recommended for front and rears? Also are there any downfall to getting spacers? Would I need longer lugnuts or longer stud bolts? Right now I have Rays 32MM lug nuts...
the is350 caliper shouldn't have a problem fitting the wheels after spacers after they are installed or that wont even have anythin to do w/ clearance? I want this set up for my brakes.....IS350 calipers...stoptech drilled/slotted rotors, stoptech stainless steal brake line, what do you guys think?
Any advise is appreciated, thanks guys
spacers will increase the clearance for your brakes, so you will be fine. Even without them the IS350 brakes will still fit inside your wheels.
I like the look of spacers. I have a set of 20mm eibach pro spacers on my rear wheel and it makes a huge visual impact IMO.
If i could go back in time i would probably run 20mm spacers on the front (or 15mm if 20mm rubs) and 25mm on the rear. It will look perfect
I see, thanks for the info. Your sig says you got 15r and 25rs, got a pic of how they look? Also..any idea where to get the v2s? Ebays are v1 I think :/
edit; i found em on ebay for like 130 each! not bad
No member with that name..there's 1 misterT with 0 posts so that can't be him
edit; i found em on ebay for like 130 each! not bad![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I don't have them yet... they are under "future mods" ... I want to get them sometime this year though. 15 looks good up front... but 20 in the back is just inside the fender. Thats why I want to get 25r, but am not sure if it will rub with a drop, like the H&R springs I am getting later on. ...
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I have a set of custom made spacers (hub and wheel centric) for 2nd is350 with studs. Here is the link, let me know if you're interested.
https://www.clublexus.com/forums/whe...ken-tires.html
niebla
01-03-11 09:06 PM
