Noise in the Fronts.
Old 04-30-09, 12:29 PM
  #31
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by GSteg
I'm going to take another stab at it. Check your shock's lower bushing. I know you said you just installed them 6k miles ago, but 6k is enough time for the rubber to deteriorate. The wear isn't due to time, but rather the from installation. If you had your shocks installed without resetting the bushings, you're twisting the rubber around and eventually it'll rip apart. It looks like your car is low so that makes it even worse.
You can also take out the shock/spring assembly and move the hub up and down to make sure it's not the UCA and LCA bushings.
Very well convincing! I need to check on that.
Old 01-08-10, 04:33 PM
  #32
mpsarmi
mpsarmi's Avatar
I have the same thing which started about 2 weeks ago. My coilovers were replaced 2 years ago and upgrade the control arm bushings to Daizen. Have you pinpointed what was causing the cricket noises GS4?
Old 02-05-10, 01:36 PM
  #33
GS4_Fiend
GS4_Fiend's Avatar
I changed the lower ball joints and lower control arm no. 2 and it still makes noise. The only thing left is the top bushing of the struts and the top hat that I need to check out.
RXGS
Suspension and Brakes
05-05-14 10:37 AM
RXGS
18
10-27-13 08:30 PM
phesa
04-14-11 05:42 AM
Neophyte2b
10-19-09 12:07 AM
Quick Reply: Noise in the Fronts.
