Can't tighten upper ball joint nut
Old 03-09-09, 04:39 AM
Frankdorn
Frankdorn's Avatar
Default Can't tighten upper ball joint nut
Strange question, I know, but I'm bolting everything back together after my lowering spring install, and the nut is going on the ball joint a little tough. I ran a tap through it and cleaned/lubed the stud threads, but the dam ball joint above keeps spinning! How in the world can this be tightened without the threads being squeaky-clean?
Old 03-09-09, 05:10 AM
fordsvtmfl
fordsvtmfl's Avatar
i thought you were supposed to use new nuts...
Old 03-09-09, 09:04 AM
GS300ToM
GS300ToM's Avatar
lower the car a little to give pressure to the joint so it wont spin.. works for me.. hope this helps
Old 03-09-09, 09:05 AM
GSteg
GSteg's Avatar
If the thread is really dirty, you're not going get it back in with easy. Try to take it out and clean it up real well. Also press the upper balljoint into the knuckle as you turn your wrench (have another helper do this?) so the knuckle can hold the balljoint still.
This is why I dont suggest removing the upper balljoint when removing/installing springs. Some people insist on doing it this way and may find themselves in this kind of situation.
Old 03-09-09, 09:45 AM
Frankdorn
Frankdorn's Avatar
Sounds good--I'll try putting a jack under suspension in that corner for some pressure.
I tried avoiding this step, but when I pulled on the shock/spring, I wasn't able to get it out. Then after unbolting the balljoints, I realized I forgot to turn the wheels out when trying. Blast!
Old 03-09-09, 10:40 AM
GSteg
GSteg's Avatar
For anyone who is going to remove the old suspension, unbolt the 2 lower balljoint bolts (17mm). It will make your life a lot easier, especially when it comes to installing again. You can practically remove and install spring/coilovers for that particular front corner in 15 min or less. Some people have luck without having to remove anything, but when it comes time to install the OEM suspension, good luck
workhands
RX - 1st Gen (1999-2003)
09-22-18 05:18 PM
timmy0tool
Suspension and Brakes
02-19-18 09:04 AM
akafixture
12-10-14 12:28 AM
jdvtec
04-30-14 11:40 AM
es30000000
12-04-12 07:56 PM
Quick Reply: Can't tighten upper ball joint nut
