F-Sport spring and struts - Who has them? Who likes them?
Old 03-13-09, 02:29 PM
  #31
nicholasg
nicholasg's Avatar
Originally Posted by Is300M.Q.
maybe they f'd up by cutting the bump stops or somthing.
Doubtful, the F-Sport struts have their own bump stops. As far as I know, nothing is migrated from the stock suspension to the F-Sport stuff.
Old 03-13-09, 02:35 PM
  #32
Kurtz
Kurtz's Avatar
Just because it's a pet peeve of mine-
Your car has shocks, not struts.
If it had struts it'd have a different type of suspension.
Old 03-13-09, 02:37 PM
  #33
nicholasg
nicholasg's Avatar
As far as the internal workings of shocks and struts, there is very little difference. The main difference is that a shock only acts as a damper and is usually mounted between the lower control arm and the body.
A strut not only acts as a shock, but it also becomes part of the suspension system. It replaces the upper control arm, upper ball joint and shock. In most cases the front springs are also incorporated, making one complete unit.
The Lexus IS models us STRUTS.
Old 03-13-09, 03:43 PM
  #34
triple_c
triple_c's Avatar
struts are a structural part of the suspension. if you take off a strut, your suspension will no longer be fixed. take off the shocks on the is, and the suspension is still held in place by the upper and lower arms. therefore these are not struts. mcpherson type suspension use struts, but not double wishbone.
there are no special bumpstops for the f-sport shocks. they use the same bumpstops as the stock suspension.
Old 03-13-09, 11:33 PM
  #35
Kurtz
Kurtz's Avatar
Be happy to bet my car vs yours you're wrong... though the previous poster kinda already explained it.
Here's a pretty good, detailed, explaination though if you'd like to learn more about the differences in Macpherson (strut) suspensions vs. double wishbone (no struts, just shocks) suspension-
http://www.team-integra.net/sections...?ArticleID=525
Old 03-15-09, 05:37 PM
  #36
IS-SV
IS-SV's Avatar
UPDATE:
Today I picked up the car. The dealer said that one of the struts seemed defective as it was not compressing correctly when they checked them all and they replaced it. They also said the washers holding the top of the strut were rubbing on the body thus resulting in the "clang" sound I had heard a few times.
The car rides MUCH BETTER as compared to before. Its like a totally different car. Suffice to say, I am now happy with my purchase.
So after replacing the defective parts, would you still recommend the F-sport suspension as an upgrade?
FLM99
RX - 3rd Gen (2010-2015)
14
08-25-16 01:40 PM
canknee
CT 200h Model (2011-2017)
01-03-15 08:40 AM
knox_sport
09-19-14 01:40 PM
gocubs08
06-24-13 12:24 PM
modthispny
03-29-13 04:06 PM
Quick Reply: F-Sport spring and struts - Who has them? Who likes them?
