Recommended Tool for Removing Rear Control Arms
I am wondering if anyone knows of any tool available that will pop the ball joints loose on the rear control arms without damaging the rubber boots. I know the pickle fork would work fine for the ball joints, but it would also destroy the boots. The pitman arm puller I have works great for disconnecting the front upper and lower ball joints and it doesn't damage the boots either.
But due to clearance issues the pitman arm puller that I have is too big to fit the rear ball joints. Do I just need a smaller version pitman arm puller? I am trying to avoid paying alot for the special service tool from toyota/lexus. I tried beating them with a heavy mallet without really any luck. There has to be some tool out there available for this job other than the SST. Anyone know of where I can find what I'm looking for? Or atleast tell me the name of what I need. I just haven't seen anything at sears or the parts stores. Thanks
So you used a pickle fork and it didn't destroy the ball joint boots? I thought that was the con of using the pickle fork. There has to be some small ball joint puller out there that will work.
I just threaded the nut back on so the top of the nut is almost flush with the top of the stud, then I ended up having to heat the spindle with a torch, gave it a few taps on the spindle to hopefully brake it loose. Then give a few good wacks with a hammer on the nut. A little pb blaster doesn't hurt either. But I also had my axles out too. Makes it way easier.
I rented (free of charge) a Pitman Arm puller from Autozone to remove my front lower balljoints without damaging the rubber on the ball joints. I hand to grind off a few mm's of the Pitman arms for clearence (just don't tell the folks at Autozone). Worked like a charm! Now for the rears, have you checked out different size Pitman Arms or tie-rod separators. Might check places like Northern Tool, or Harbor Freight. Let us know if you find a tool other than the SST that works. Would be really great to know what works other than a pickle fork which I do not much care for.
GrantReid
Suspension and Brakes
04-15-17 06:18 AM
kevvo
12
09-24-15 02:11 AM
BoostAddct
11-24-11 07:23 PM
