Coils Help
Coils Help
First of all, I have no background on suspension. I have a general idea of how it works but don't know all the mechanical components involved. What I really want to do is to lower my car without sacrificing the comfort. I have read for hours on H&R and tein springs threads and I think I am moving towards coils.
I am looking at megan, teins, tanabe, bc racing, and d2. For the price, which one should I go with? I like to drive fast around the corners but also have bumps in my neighborhood so I want some improvement on handling but doesn't want to sacrifice much on comfort.
Also, if I decide to go with the tanabe and later wanted TEAS, is it possible to hook it up without taking off the coils? Since I won't be installing it myself, I don't want to pay the shop everytime I make a change. And if I get a system like TEAS, when do I get an alignment done?
Does TEAS only change the stiffness or does it also change the ride height? If I do not get TEAS and I want to change stiffness/ride height, do I have to take out the coils again? Sorry for those noob questions but I just want to get things done right.
Soon after the coils, I plan on changing my wheels to 19" probably so what changes do it need to the coils? Or should I get wheels first then the coils?
Thanks in advance!
Thanks in advance!
if you are looking stritcly based on price megan is the way to go. all the other coilovers out there are good and bad depending on what is more important to you and how much you are willing to spend. i didnt know that tanabe had the Teas system but from the website it looks like it only adjusts for damping, which means only on ride quality i.e stiffness, etc. if you wanted to raise it higher or lower it seems like you would need to use handtools to do that, just like for other coilovers. Alignment generally should be done right after you get it lowered, corner balancing is also a good idea. wheels and coils are two seperate things, it doesnt matter which you get first
Thanks. All the prices are around the same range. What's important to me is comfort and just lowered. I don't want it all the way to the ground or anything. I like H&R and tein's drop but they are on springs. Just thinking around 1.5" drop while keeping stock ride quality but better handling :P if possible.
So TEAS can be added later on or needs to be installed at the same time? Thanks.
I know people will complain either way but based on what I've mentioned, which coil should I choose? 1.5-2.0" drop with better handling but same ride comfort. Thanks again.
