IS350 front brake
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
hi to all the break guru in here lolz, have anyone knows or try using extra is350 front break=including rotter and break caliber install in the rear wheel of is 350? is that possible , isnt better performance ? and look much better ? i know woudnt need alot of power breaking in the rear but just a thought, anyone ??
brake*
its possible but:
the extra braking pressure of the larger brakes would throw off your brake bias, possibly be dangerous, and the only way to possibly counter it is to some how change the braking pressure in the rear given the now larger contact area to match the oem spec
its possible but:
Ho Motorsports
Kurtz is the CL official BBK police.
Having said that, it's not worth it to make such an attempt. Your stock brakes are more than enough to stop the car. If you want to have a bigger caliper, you might as well go with a set of aftermarket BBK.
Terrance
Terrance
