Coilover/CA bushing question...ScARY
Honestly if you are having a shop do the CA than having them swap the coils since they are already in there makes a lot more sense. In order to install the Daizen bushings the whole spindle and hub comes out, than the ball joint, outer tie rods, than lower control arm and caster arm, than the upper control arm. Take it to a shop have it pressed out if you are hell bent on doing it yourself. Reinstall in reverse order.
When you do the bushings you will need a realignment same when you do the coils makes no sense to do the coils if the shop will be doing the CA bushings. Here is a pic of my front suspension apart for the bushing change just to give you a picture of what I mean, and this is before I even removed the lower control arm and caster arm.
![](http://img.photobucket.com/albums/v296/Spyder78/Lexus%20Gs/f6fa5896.jpg)
yeah that was my plan, either that or having the bushings done, going straight back and installing the coils myself, then going and getting an alignment. But 850 seems crazy even for that...
thanks man, i'm shopping it around a little so i'll definitely let you know. Torching should work alright on those no? I mean wouldn't it either melt or contract the rubber and leave the metal fairly untouched?
Just get someone with a press and be done with it. Torching takes forever and even if you get the rubber out, you still have the metal sleeve to deal with. Trust me i've gone through this and there is no easier way than having them pressed out. My friend (shop owner) does the whole job in just 3-3.5hrs and he doesn't have to cut/torch anything.
yeah, i just got another quote today from a more reputable shop and they said about 550 with an alignment (inclusive of changing out all the bushings, installing the coils, and alignment). Seems better, but I put a call in to one of my friends that works at another shop and i'll try and get a better number.
Yes; there are wheel bearings on the front wheels. I do not have an answer on how often they go bad. However, you can test it by jacking the car up and checking for play. If there is play in the wheel, then it is bad. Also, there should be a low humming sound when the car is moving.
416tt
05-24-14 10:49 PM
quickex99
Florida Lexus Club
01-07-09 04:23 PM
