Replaced control arms; no luck
Old 04-17-09, 11:07 PM
TexusLexas
TexusLexas's Avatar
Default Replaced control arms; no luck
Hey guys, I have a 2000 GS300 and know that the lower ball joints should be replaced. So I bought a pair from Carson's (~$145) and threw them on. I still have the same clunking noise coming from my passenger side while driving on rough surfaces at about 10-15mph. Any thoughts on what it might still be? Please help! Thank you for you time
Old 04-17-09, 11:13 PM
Infamous 1
Infamous 1's Avatar
Is your car lowered?
Old 04-24-09, 01:21 PM
StayBroke
StayBroke's Avatar
Same problem here but on the driver side
Old 04-28-09, 08:28 AM
Rick James
Rick James's Avatar
Upper control arm.
Old 04-29-09, 09:42 PM
tom steele
tom steele's Avatar
did you check the castor arm bushing thats were most of the problems start
Old 04-30-09, 12:36 PM
GS4_Fiend
GS4_Fiend's Avatar
Isnt the castor arm and lower control arm the same synonym?
Old 04-30-09, 08:29 PM
RI-Lex
RI-Lex's Avatar
sway bar end links
Old 05-04-09, 08:56 PM
Vic Nyce
Vic Nyce's Avatar
Originally Posted by Rick James
Upper control arm.
dont neglect it. i went in to replace a wheel bearing, and while checking for that, my mech discovered a wobble in the upper control arm ball joint...on top of the worn wheel bearing!
Old 05-05-09, 04:32 PM
GS4_Fiend
GS4_Fiend's Avatar
Soo many answers, might as well replace the car.
Jason12327
Suspension and Brakes
09-10-18 08:33 PM
GsLex02
GS - 1st Gen (1993-1997)
07-31-18 11:53 AM
kontrazeus
09-29-17 08:33 PM
Clear2Cloz
11-04-11 09:04 AM
questnyc
05-31-09 09:08 PM
Quick Reply: Replaced control arms; no luck
