is-f brakes can they work on.........
Most brake systems will work fine for the average user, most cars have roughly about the same forward inertia to stop (as for the brake bias) post earlier posted)..
The mounting hardware will be like 150 or something?
search for LS430 brakes on the 2gs forum.
go with ls 400 calipers 98 up they are four piston and bolt right up just need rcas to clear tie rod bolt i did mine for under 400 bucks autozone calipers 95 dollars core 65 did not turn them in same day so they cant compare what your trading in so you take your calipers back the next day for your core rcas i made for about 10 bucks then drilled and slotted rotors from ebay 130 and i know everyone hates these rotors but htere cheap and they get you started you can always upgrade the rotors later this in my opinion is the best route unless your made of money
