daizen control arm bushings to Stock
black_GS99, can you tell us about the wheels/tires/springs/inches of drop you've got on your car? It would be helpful to know so that we can gauge "your level of pain".
Upper, lower, caster arm.
For the lower control arm, Toyota sells OEM bushing (camber bushing) for under $10 each so you dont have to buy a new arm. You need to have them pressed in though.
I only did the caster arm bushings knowing the upper and lower bushings are what makes the ride rougher. If I was in your shoes...I'd replace the lower camber bushings with OEM first since it's the cheapest. The ride will be softer, but if it's still not enough, replace the upper control arm next. Finally the caster arm if the ride is still unbearable.
![Over Here](https://www.clublexus.com/forums/images/smilies/overhere.gif)
Does anyone have the part number for these? I would really like to get them if possible, thanks.
Toyota doesn't offer any control arm bushings as a replacement. You have to buy new arms. However, they do/did have a replacement bushing for the lower control arm (where the camber bolt goes through). I'm not sure if you can still get them but I think I may have posted a part number before.
These are the upper control arm bushings that are the problem, correct? And from earlier osts, we can buy stock replacement lower CA bushings?
Anybody have the part number for the caster bushing?
GSteg
02-09-10 09:08 AM
