Squeaking brakes!!!! :(
OK, so I got brand new brakes installed about 3 weeks ago, the guy called me in the middle of the job saying that my rotors were bad and if I don't replace the rotors my brakes are going to squeak. When I left the shop they were not making ANY noise (note: my old brakes weren't either). After a few weeks of driving they started making some noise, now its TERRIBLE I can hear it with my music bumping and my windows closed, I don't know whether he installed bad brakes or it is really the rotors that are causing this, I asked another mechanic and he said, "they gave you crappy brakes". Now I do not remember what brand brakes they installed but he did say "this is what Lexus recommends" The brand name might have started with the letter B but I can not say for sure at this point. So I wanna hear some opinions, can rotors cause this terrible noise and if so why haven't my old brakes made this noise also is there anything I can do to reduce it, I don't want to buy new rotors right now (he quoted me 300$)
Thank you guys !
Thank you guys !
Brand new rear brake pads were installed.. By the way thanks for your quick reply
Just turn the rotors, which if your not familiar, it just means they refinish the face of the rotors. I jsut got mine done a few weeks ago. Before getting them turned I could hear the squeaking when i barely pressed on the brakes. Soooo annnoying.
I paid $40 to get all 4 rotors turned, but a freind hooked me up/ I think it might be a tiny bit more normally.
its the rotors, you are never supposed to replace the pads without turning the rotors...technically at least. and if they were bad enough, they cant be turned, and $300 is about right if all 4 are bad. (the reason you cant just turn the rotors if they are really bad is because they will get under spec, too thin, and then will over heat..etc, so if you take it back and your mechanic says that...he isnt necessarily full of it.
every rotor contains a spec. should it wear beyond the measured spec, your rotor is shot and will need to be replaced. the squeak/squeal from applying your brakes can be caused from a number of faults- lack of brake grease, anti-ceramic pads, shot rotors, foreign object lodged in between stone protector shield, etc. it's difficult to say without facing the problem head on. either get a second opinion from another shop, or DIY. good luck.
If you go to like rockauto, then you can find third party manufacturers under brake hardware.
Or if you go to like Sewell, you can find the "Brake fitment kit" under the common maintenance parts for the 2GS. You can either buy from there, or just take the toyota part # and buy it from any other toyota parts vendor.
If these are getting loose, you will typically get a single "clunk" sound (not squealing) when shifting from Forward to Reverse (and vice versa) on your first brakes application.
The clunk itself is not a sign of any problem with your car or technical design, your brakes will still work fine, it's more of a nuisance item.
ow yeah i was just asking cuz i lost mine. and its really annoying hearing clunking. thanks
