Sage RCA's Installed...Pictures
Old 04-26-09, 01:06 PM
GSteg
GSteg's Avatar
If you can remove (2) 17mm bolts, then it'll be EASY.
Old 04-26-09, 01:13 PM
FLIPMOE
FLIPMOE's Avatar
Old 04-26-09, 01:30 PM
swat1727
swat1727's Avatar
this is a noob question, wut does the RCA do?
Old 04-26-09, 02:11 PM
Anthony
Anthony's Avatar
how much lower did the car get after the rca's were installed?
Old 04-26-09, 06:54 PM
olemanGS
olemanGS's Avatar
Originally Posted by denut-L
Do you have before pictures? maybe some close up before and after. I'm thinking about getting some. How's alignment. Thanks
The rears have a camber insert so its as easy counting to 3 to adjust....Its a great product....if they made them lower than 1.1 i would get them and change my springs.....I having trouble posting pictures but I do have before and after....but just to say I had a two finger gap before now I have none at all in the front and rear.
Old 04-26-09, 06:57 PM
olemanGS
olemanGS's Avatar
Originally Posted by DASHOCKER
Nice job! If you have coilovers, you should lower the rear some more. How is the ride and drive before & after? My F&R kit is still in the shipping box lol..
Thank you and the ride is no different than it was at 1.8 front and 1.7 rear with the tein s-tech springs....It was wierd to me that it dropped the car like that...I like the way it sits.....
Old 04-26-09, 06:59 PM
olemanGS
olemanGS's Avatar
Originally Posted by ZippyGuy
PHML
On a scale of 1 - 10 with 10 being the hardest, how difficult was it to do the fronts
I did all four in a hour and ten mins.........
Old 04-26-09, 07:04 PM
olemanGS
olemanGS's Avatar
another 1.1....i didnt think that it would take out all the wheel gap but it did...I dont have my rear lip rolled and I run 245/35/20 on a 20x10 in the rear 40mm offset and I cant put my one finger between the tire and the lip in the rear.....perfect fit....im very happy with the product......
Old 04-26-09, 08:26 PM
Anthony
Anthony's Avatar
damn if you had some dazien or sprint springs you'd be tucking..
Someones going to do this..
Old 04-27-09, 05:16 AM
esolo98
esolo98's Avatar
Nice drop
Old 04-27-09, 06:39 AM
LEXUS_KID
LEXUS_KID's Avatar
Looks good
Old 04-27-09, 08:38 AM
olemanGS
olemanGS's Avatar
Default More Pictures.....
Im having trouble uploading some of these pictures from my camera...
Old 04-27-09, 10:45 AM
sakataj
sakataj's Avatar
nice job sir...always nice when someone else is the guinea pig for me
Old 04-28-09, 12:42 AM
PHML
Master Thread Closer!!
PHML's Avatar
PHML
It was a 2 for me...pretty simple....jack up car, put car on jack stands, remove wheels, remove 17mm bolts (2 on each side) under lower ball joint, jack up the brake rotor assembly (a bit heavy), position RCA in place, re-install brake rotor assembly over RCA, torque new bolt/locking washer/ o-ring to min. OEM specs (81 ft/lbs)...DONE!!
Do NOT torque to 120 ft/lbs!!!
Old 04-28-09, 12:51 AM
PHML
PHML's Avatar
By the looks of it...your rears does NOT show any negative camber issue...and you're only using the middle insert too....look like its within specs...even at this low drop.
Quick Reply: Sage RCA's Installed...Pictures
