A whistle from where???
Old 04-27-09, 07:15 PM
rykwebb
rykwebb's Avatar
Default A whistle from where???
Front right wheel is whistling...but when I apply brakes it stops.
Usually after I've been driving it for 15 minutes (heating up?) and only at speeds <40mph.
Is this the rotor? the caliper? the pad? Any ideas on what to get fixed? I took it to Midas and they said nothing was wrong buuuuuut I hear otherwise. Thanks CL.
Old 04-27-09, 10:54 PM
sc4002soar
sc4002soar's Avatar
hub bearing, whts ur wheel setup
Old 04-27-09, 10:55 PM
LiCelsior
Retired
LiCelsior's Avatar
its the hidden bov from the hidden turbo.
Old 04-28-09, 07:16 AM
rykwebb
rykwebb's Avatar
Haha, yeah the hidden turbo that I don't even know about...
I'm sitting on 19s, 245s in the front, I just replaced my wheel bearing for the front left because it was 'clunking', is the hub bearing a completely different thing?
Old 04-28-09, 08:47 AM
scfocus
scfocus's Avatar
It's the same thing and I'd think it would have something to do with the brakes
Old 04-28-09, 09:48 AM
UZZ30-SC4
UZZ30-SC4's Avatar
Is the wheel or caliper very hot after driving for a while, is there excessive where on the pad in that corner?
Old 04-28-09, 01:50 PM
rykwebb
rykwebb's Avatar
Not as far as I can tell, everything looks alright, but I'm thinking it HAS to have something to do with the brakes, seen as when I press the brake pedal it ceases. My rotors don't feel chunky when I apply the brakes so the rotors can't be warped, only things left are the pads and calipers...
Old 04-28-09, 03:47 PM
UZZ30-SC4
UZZ30-SC4's Avatar
Put the car in the air and spin the wheel, see if the pad drags, see if you hear the noise and can pinpoint the location, if nothing take the wheel off and have someone work the brakes, see if the bite and move away like they should.
Old 04-28-09, 05:53 PM
rykwebb
rykwebb's Avatar
Will do UZZ
Old 04-28-09, 09:13 PM
QwkSC
QwkSC's Avatar
First off does the whistle change in pitch at you decelerate? if it does then this is my guess as well. When you brake, it puts stress on the front side of the bearing, causing that whistling. Why not under 40? because the bearing isn't moving fast enough for you to hear the whistle OR theres not enough braking force to put ample stress on the bearing. Similarly, when the bearing isn't warmed up yet there is no whistle.
That's also why i don't believe it's brakes. It's because brakes would heat up to temperature very quickly and are not related to the temp of the engine.
Old 04-28-09, 09:58 PM
rykwebb
rykwebb's Avatar
Ohhh, I'm sorry QwkSC, it only squeaks UNDER 40mph, sorry for misleading.
Also, only the smallest press of the brake pedal and it stops.
It is VERY loud, it doesn't change pitch.
Thanks for all the help guys, I'm going to get it jacked up within the next couple of days and see if I can spin the wheel and get the same sound, we'll take it from there.
Cheers.
Old 04-28-09, 11:16 PM
QwkSC
QwkSC's Avatar
Cheers.
LOL -1 for not reading carefully hahaha
Old 04-29-09, 10:43 PM
cactusmole
cactusmole's Avatar
I have the same thing happening to me. But it the rear left wheel. Sounds like a very loud metallic scrapping sound. Usually happens when I first start driving. I lifted the car, spun the wheel and could not here a thing. I you figure it out, and If I do first I'll post it up in here.
Old 04-30-09, 12:04 AM
abounly
abounly's Avatar
My brothers 2IS had something like this he solved the problem by going at 60 and slammed the brakes 60 - 0 and it stopped i'm not sure if that will work for your car. Please inform us whats the problem!
Old 04-30-09, 09:06 PM
rykwebb
rykwebb's Avatar
Holy crap...ummm......I guess I'll try that...for lack of better options. It's finals week in school and I don't have time to give the car a thorough looking at yet.
I'll post as soon as I know something.
Quick Reply: A whistle from where???
