anybody have the d2 air suspension??
Old 04-28-09, 01:00 PM
jasonlee
jasonlee's Avatar
Default anybody have the d2 or ksprt air suspension??
i was wondering is anybody have the d2 or ksport air suspension? wanna know if its worth getting and hows the ride. any info would help thanks
Old 06-29-09, 08:51 AM
RonV
RonV's Avatar
I will let you know in about 3 weeks I have D2 Air coming
Old 07-03-09, 11:17 AM
vwynn
vwynn's Avatar
its the same as Ksport i believe..
Exclusive aka rideslow has em n loves em. imma be getting ksport in about 3 weeks as well.
Old 07-03-09, 01:03 PM
Alexus_300
Alexus_300's Avatar
looks the same but built differently...
Old 07-28-09, 02:09 PM
andrew m.
andrew m.'s Avatar
in comparison, the d2 setup is using paddle valves. paddle valves are a very simple form of valve and have been around for ages. whereas the ksport kit is using momentary switches or rocker switches for height adjustment. the bags themselves look to be the same between the two kits. the management setup for either kit is very very basic and it does not specify if the components are DOT approved. components being the fittings and air line. fittings that are not DOT approved have a tendency to leak and most times they end up leaking. if you're willing to spend that kind of money on an air suspension then do yourself a favor and buy DOT fittings. a DOT fitting has an inner crush seal that eliminates air from escaping through the fitting. most of these DOT fittings can be sourced via an industrial pipe fitting store, air brake supplier or diesel technician. i'm interested to see some feedback on the d2 and ksport kit.
Old 07-28-09, 02:39 PM
vwynn
vwynn's Avatar
seen the ksport n installed it. the fittings are fine... put the hose in the fitting and screw in the nut looking thing tight so it crushed the hose to fit the shape of the bulging thing.
Old 07-28-09, 02:41 PM
andrew m.
andrew m.'s Avatar
wow, i would have expected at least some sort of PTC fitting. for the amount of money k-sport wants for that kit and what you receive is absurd. there are other solutions out there which are less expensive and have much better quality components.
Old 07-29-09, 10:07 AM
I'mStock
I'mStock's Avatar
Examples, please?
Old 07-29-09, 12:07 PM
vwynn
vwynn's Avatar
you dont actually pay MSRP price ya know
our vender Rides Low is selling the kit for a good price.. its a good kit for a PNP set-up.
Old 07-29-09, 05:52 PM
Rides Low
Former Sponsor
Rides Low's Avatar
Thanks for the plug vwynn.
My price for the KSport kits are WAYYY below the msrp and there is not one thing that needs to be modified for a proper installation. Install the strut/bag combo just like you are installing a new set of coilovers - it comes with the top hats - and run lines/wire up everything and you're done. A little more time consuming than it sounds, but with the price my kits go for, you can upgrade the kit for days before you reach AirRunner (basic system) pricing.
PM me for pricing
Chris
Old 08-01-09, 02:09 PM
TomLee
TomLee's Avatar
I heard that the materials used in these coils arent that strong?
Old 08-01-09, 03:19 PM
On3_Lo35
On3_Lo35's Avatar
I will be ordering D2 air suspension shortly, D2 east coast's distributor is like 30 minutes from my house so that's the reason why I went with them, if some kind or if any defects were to happen I wouldn't have that much downtime, I'll keep you guys posted on how D2s will go..
Old 08-17-09, 12:01 PM
ARD LS
ARD LS's Avatar
so any updates?
Old 10-21-09, 06:17 PM
On3_Lo35
On3_Lo35's Avatar
My D2 Air Suspension is arriving next friday
Old 10-21-09, 07:15 PM
ARD LS
ARD LS's Avatar
Oh sweet, what car do you have and where did you buy it from? Can you post the priceor PM it to me?
Quick Reply: anybody have the d2 air suspension??
