Help identify noise
Im getting a thumping/clanking noise on the front end of my 400 seems like is only when making a right turn or taking off from a total stop, I've tried pushing up/down on the (R) fender to see if it makes the noise (nada doing this), basically im trying to identify if it's the ball joint or tie rods, is there a sure way to tell, im taking off the wheel tomorrow to have a closer look, and if it is either one of those 2 things should I just replace that specific side or both sides necessary, I ask because are kinda low right now
where's the best price for these sewell or carson?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
check your control arm bushings mostly the castor arm bushing does you car front end shake at 55-65 like your wheels are out of balance or you have warped rotors sometimes it you bushings check those they seem to go out quick on these cars
