Front Strut Question
Has anyone seen this before? does anyone know if it improves anything? thanks!!
http://cgi.ebay.com/ebaymotors/LEXUS...ht_1838wt_1194
Tech Info Resource
It improves the seller's cashflow. That's about it. It also puts a shiny thing under your hood that impresses people who like shiny things. It doesn't measurably improve the car's mechanical performance.
hey please be careful! It won't do anything.
Please correct me if I am wrong but here it goes.
We have RWD. Front struts won't do much. With that fact... these ebay ones.... bleh.... nothing will happen. Also, it will end up you having the engine cover gone.
If you realllly want to get a front strut... all i know there is as I can remember is the Jun-tw front strut, gt-spec front strut.
I have seen a jun-tw front strut work with the engine cover on. They are priced for 230ish, but you might be able to find some deals here which might be aiming for around 160ish. I PMed someone, I can't remember and he sent me a quote for 160. GL finding! (still... even with good front struts, its hard to tell a difference )
As for the effectiveness of this STB, I cannot say but probably not much since its just a single bar (not triangulated with the firewall). There are better ways to spend your money like a performance driving school, tires, etc.
Shocks control the motion of the springs.
Struts, which the 2IS doesn't have, besides dampening spring motion, are actually a structural part of the suspension.
You can remove a shock and have a complete suspension, just no spring dampening.
You can not remove a strut and have a complete suspension.
You can't drive fine without a strut, since your suspension would be missing a necessary part of its geometry.
That's why a strut tower bar on a car with struts is rather more useful than it is on a car that doesn't have them (to get this back on topic for the thread)
On a double-wishbone suspension like ours that force isn't similarly being created, so all the bar would do is add a very tiny bit of stiffening to the body, at the cost of adding dead weight above your center of gravity.
It's possible that if you were on slicks, on a prepared surface, and had already done every -other- possible handling mod (sway bars, lighter wheels, coilovers, and any possible bracing _under_ the car) then at that point a good strut tower brace, triangulated to the firewall, would offer a minor performance benefit.
But on street tires, on street surfaces, without having done all the rest, using a cheap ebay bar that just connects the two points in the engine bay? waste-o-money.
macpherson strut designs inherently create a fair bit of force at the top of the strut under cornering.. the strut brace will help counter this force.
But the forces are the same but there should be a bit less lateral but thats a generalization because it depends on the angle of the shocks and struts to compare. The shocks can take the same force as the strut - just the angles and motion ratios, which the struts tend to be closer to 1:1. I just think your statement assumed too much...
First, lets agree its a waste of $.
How do you figure the forces are the same?
On a double-wishbone setup the wheel assembly is independent of the shock assembly... when the wheel assembly turns, the shock assembly is stationary.
On a Macpherson setup the wheel is located below the spring and shock assembly. The spring and shock assembly sits on a ball joint of a single lower arm connected by a tie rod. The single lower arm is usually an "A" arm. The top piston rod is used as a swivel axis. This is necessary, because with a Macpherson suspension, when the wheel is turned, the whole suspension system turns with the wheel.
In the end they both support the weight of the car and the forces from the wheel/tire are transmitted into them both. Primary difference between them is the ratios of the suspension. I see you point but I think you are exaggerating how much. Structurally both shock and strut towers on the chassis are built equally.
johnnyo808
03-15-05 05:44 AM
