Spring sleeve removal question
Old 05-05-09, 03:21 PM
blue99GS4
blue99GS4's Avatar
Default Spring sleeve removal question
All,
When I had my suspension upgrade done, the tech put a sleeve around the bottom coil (where it's closet to the ground) at the rear wheel to avoid coil slap, which is a common problem with after market springs. Updon doing research in the forum, there's no apparent evident that my specifict type of spring (Eibach) will do that. I would like to remove these sleeves to restore the intended relative ride heights between front and rear wheels. What is the easiest way to do this?
If I were to jack the car up, would there be enough "play" on the springs that I could just push it up to remove the sleeves?
Thanks,
Old 05-05-09, 08:54 PM
GoFaSSter
GoFaSSter's Avatar
I do not know exactly what a spring sleeve is, but there is no room to push the spring up when still bolted to the strut. The spring is under at least a little compression when bolted to the strut.
strikeraj
Suspension and Brakes
05-05-16 11:14 AM
RCPnoi
08-24-09 04:43 PM
trinituner
12
07-11-09 06:08 PM
1moGS4
12
12-31-07 04:55 PM
EGainer
08-07-02 08:18 AM
Quick Reply: Spring sleeve removal question
