View Poll Results: What do you think about DIY RCA'S ?
Are you crazy , this will never work !
33.33%
Sounds interesting but i am no DIY never mind fabricator
33.33%
Why didn't I think of this first !?!?
11.11%
I'm going to do this the easy way .
11.11%
I'm going to do this with a cnc and maybe have the program available for others FOR FREE
22.22%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
Is it possible to make your own RCA's for much less? Here is some ideas.
Old 05-08-09, 09:42 AM
  #31
GSteg
GSteg's Avatar
Originally Posted by GS FONZy
WTF!, how come I had to pay way more than $30
Long story short, I did some detailing for him
Old 05-08-09, 10:10 AM
  #32
GSteg
GSteg's Avatar
sam430, are your RCAs 1-piece design? The metal sleeve should be at least steel, and it should extrude into the RCAs just like the OEM balljoint design. Integrated sharp edges like that are considered defects since you have a higher value of radial and circumferential stress. If they are indeed 2 piece design with the sleeve being steel, then ignore my post. It just hard to tell from the picture
Old 05-08-09, 10:16 AM
  #33
sam430
sam430's Avatar
"It's very well made", was my first impression. The sleeve's are like the oem sleeve... as far as I can recall. Not 100% sure ... it's very likely two pieces. ... I doubt it's an aluminum sleeve. I will take a look when I install my TRD sway.
Old 05-11-09, 10:56 AM
  #34
sam430
sam430's Avatar
Anyone releasing their cad or planning to, for the RCA?
Old 05-13-09, 10:11 PM
  #35
skperformance
skperformance's Avatar
Hey GSteg or Tom steele, any chance you found some time for pics?
thanks
Old 05-14-09, 09:04 AM
  #36
Vic Nyce
Vic Nyce's Avatar
kind of late into the discussion, but if anyone here is homebrewing a set, i wouldnt mind kicking in some money to fund the project.
sam's one piece design seems to be doing the job. i'm no engineer but i can understand how a one piece design would be less susceptible to breakage in hard cornering.
props to all you guys for thinking outside the box.
Old 05-14-09, 12:51 PM
  #37
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Originally Posted by CK6Speed
Got any pics? THe Sage and Exact ones are basically the same design, just I think the Sage is a tad thicker at 31-32mm or something. How does the one you guys have look like?
Exact RCA's are 38mm thick. From what I can tell from the pictures posted, those look less then 25mm thick.
How thick are the Sage?
Old 05-14-09, 01:05 PM
  #38
macd7919
macd7919's Avatar
The Sage I believe are 30mm thick (1.18").
Old 05-14-09, 06:05 PM
  #39
PHML
Master Thread Closer!!
PHML's Avatar
yes....SAGE front RCA is 30mm.
Old 05-14-09, 09:32 PM
  #40
skperformance
That is why it would be nice to have sandwich plates.
Then you could supply flat spacers with sleeves built into each (not the best) and 4 bolts holding all the plates together with different sizes of nuts and bolts.
Then you could dial in drop and camber adjustment perfectly.
Also it would reduce lathing the plates ad it would now just be an outline of each peice as the top which has to get around the ball joint would not be connected .
Old 05-14-09, 09:51 PM
  #41
kit cat
kit cat's Avatar
If anyone can make me a set front and rear that looks like the Sage and Exact ones with the adjustable rear camber inserts and sell them to me for $100-$200 I'll buy them and even be a distributor for them in my area. We can make a killing I think
count me in too for the rears too.
Old 05-29-09, 04:07 AM
  #42
skperformance
Any more pics of front or rears?
Old 05-29-09, 05:41 AM
  #43
SoCal Cyco
SoCal Cyco's Avatar
i would buy a set for around $250 or less in a heart beat. please make this happen. that would be awesome
Old 05-29-09, 07:08 AM
  #44
DASHOCKER
DASHOCKER's Avatar
This may get you guys that want to save $$ jumping.. This replaces the stock eccentric bolt in back.. Anyone want to be the guinee pig?
Ingalls Engineering Adjustable Camber Kits Adjustable Camber Kit - Eccentric Bolts - 17mm - Toyota - Lexus - Pontiac - Scion - FrontBrand: IngallsMfr Part #: 35450Be the first to write a review
Not all camber kits are created equal! These adjustable camber kits from Ingalls Engineering have a Posi-Change feature, allowing camber changes up to 3 degrees positive. Each block displays a vertical line above the bushing that represents a 2 degree positive change. Don't trust your wheel alignment to just anyone http://www.streetperformance.com/par...022-35450.html
Old 05-31-09, 09:52 PM
  #45
skperformance
Hmm , so it basically allow double the degree of camber toe adjustment by having an off centered lobe .
When i have some time i just might have to see how much it costs as that would be eaiser to buy than make.
Unless it is a matching one to an existing toyota part since it comes with the same set up for other arms from Toyota . Then you can use a normal offset cam with degree markings.
Quick Reply: Is it possible to make your own RCA's for much less? Here is some ideas.
