JDM Aristo Strut Tower Bar
Old 05-26-09, 12:39 PM
sakataj
sakataj's Avatar
Originally Posted by Coco-bun
by raising the car, you free up all the load that goes on to mounting points...and when you lower it, it puts equal pressure on the bar. or something like that, it makes sense in my mind but I was taught by someone who actually knew what they were talking about.
so should i redo mine with it jacked up then?
Old 05-26-09, 09:10 PM
istundra
istundra's Avatar
so, i installed mine just now on my '03 GS300.. with the engine cover off.. i bolted it down and noticed it only clears by several MM... should i worry about it touching?
Old 05-26-09, 10:06 PM
macd7919
macd7919's Avatar
No it will be fine, have fun with it
Old 05-28-09, 08:11 PM
istundra
istundra's Avatar
great. here's mine.
Old 05-29-09, 09:18 AM
sakataj
sakataj's Avatar
co-co...so should i undo mine, jack it up and re-install it?
Old 06-02-09, 10:34 AM
MrG4Life
MrG4Life's Avatar
Originally Posted by sakataj
y are u supposed to jack it up to install it properly? i installed mine i got from chris (ck6speed) which is the one pete (Phml) sells and i installed with car just sitting there....did i make a boo boo?
I too thought you can install the bar w/o having to jack up the car. I saw a guy do it while all four wheels of the car were on the ground.
Old 06-02-09, 11:19 AM
sam430
sam430's Avatar
Just thinking about it..., if you raise the car up and then bolt it down, it'll give a pretensioned effect once the car is lowered. I'm just wondering why it would flex so much as to need one.
I guess I may get one of these...
Old 06-03-09, 01:26 PM
sakataj
sakataj's Avatar
so.....no1 has said. should i raise mine up and re-do it?
Old 06-03-09, 08:59 PM
MrG4Life
MrG4Life's Avatar
great. here's mine.
Did you have to leave the cover off to install yours? I'm thinking of buying a TRD bar and really don't want to have my cover off just to install the bar.
Old 06-04-09, 07:19 PM
istundra
istundra's Avatar
Yes. Unfortunately for the 01+ GS300, you have to remove the engine cover. Not too sure about the older GS300's.
Old 04-26-10, 06:55 AM
jjbenzo
jjbenzo's Avatar
Does anyone have the OEM Toyota part number for the stock Aristo front stut bar?
Old 05-03-10, 09:07 AM
jjbenzo
jjbenzo's Avatar
Nobody here knows the OEM Toyota Aristo front strut bar part number?
Old 05-03-10, 11:51 AM
PHML
Master Thread Closer!!
PHML's Avatar
Try posting up in the 1GS section. This stb is from the 1GS...and luckily fits the 2GS.
boostedGS
05-04-11 01:10 AM
monkiwrnch
04-01-10 08:53 AM
istundra
10-09-08 07:30 PM
Quick Reply: JDM Aristo Strut Tower Bar
