Where Besides Tirerack Sell Branbo Blanks?
I need to get these rotors asap and tirerack as them on back order. Anybody else know where else sells Brembo blanks?
Did you call and check with the site that I had the linked to in your other thread yet? To be honest with you, Brembo makes one of the crappiest blank rotors on the market. You're better off with rotora or DBA if you're going aftermarket. If not, stick with the OEM rotor since they will outperform the brembo's all day long. Your last chance it to call up these guys here: http://www.raceshopper.com/rotora_price_request.shtml
Besides now, I've heard nothing but good thing about the Brembo blank replacements. I would prefer to get those, plus I already have a new set of Brembo blanks for the rear already.
You do understand what FTL means right? Also, it's fine for you to run brembo in the rears as their isn't alot of braking done, but for the fronts, you'll want something that is tested and proven to last under hard braking. Rotora's is perfectly fine for this application if you don't want to fork out for the DBA 4000's rotor.
I will PM you shortly.
