thanks. I saw that someone mentioned these dont come with the outer shell for the bushings like some other kits do. Do the daizen bushing kits come with the outer shells? Would it be worth it to get a set that replaces the outer shell also?
dont need the outter shells.
The outter shells are only worthwhile if you have a press that can press out the original bushing in one peice (with the shell)
then you can press in the new bushings (with shell)
most ppl just heat up the rubber and chisel it out then clean out the rubber.
The strut rod bushing, where the strut rod meets the spindle doesn't fit. Looks like the metal sleeve has to be removed...PITA. Don't know how I am going to do that. I would rather just have a smaller bushing...
are these bushing kits for all years sc or just pre 97?
i think the rear kits fit all years but the front kits are only designed for pre 97. I think they changed the lower control arms in 97 (might only be for supras) but check to make sure
