just got some rims and the rear is to big(staggered) any help
just get them and put them on and they loooooked good loved them but as i started driving i hear the back hit the wheel over speed bumps and some turns any help on how to stiffing up the back so theres no bounce the front is 19x8.0 and the rear is 19.9.5 thats the problam ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
It looks like you're at stock height. So if it's hitting on stock springs, any lowering spring will just make it worse. Doesn't matter if they're stiffer or not. The best course of action is probably to get your fenders rolled or shaved. That will likely solve the problem. If it doesn't, maybe you should consider getting a slightly less aggressive offset. If you're set on that set of rims though and modding the fender doesn't cure it, you can always stretch the tires or run more camber. Both of those involve a lot of compromises though.
19's are defenitely too big for that aggressive offset without doing any mods to the fender. The only real way to correct that is what VIPJOSH and shodow191 idea is to roll and stretch the fender. Stiffining up the suspension will help but for you not to rub you will have to stay at stock height and your ride will be very stiff to prevent rubbing.
I have a very aggresive offset on my old wheels which was 17x8 +8 offsett in the front and 17x9 +14 in the rear and my wheels def stuck out....after switching to coilovers i had the stiff ride that i like and i didnt rub as much except for high speed bumps on the high way and high speed cornering and so you understand that aggressive offsets dont have any real performance benefits except for an aggressve look unless you stretch out the fender so that the wheels tuck in, then you're good
hope this helps you out a bit
well you havent even said your offset or suspension or tyre sizes. to me that fitment doesnt even look all that aggressive. All you need to do is remove the fender trim and get the guard shaved or rolled a bit. Otherwise, on a 19x9.5 what size tyre are you running? you could easy run a 245/35 for some stretch for clearance. Also, what camber are you running? you can easily run anywhere up to -2 to -3 degrees without premature tyre wear provided you get the car properly aligned for toe...
edit- and why the heck have they bashed balancing weights onto your nice new wheels!?!? wtf man?? you use stick on ones on the back of the wheel
[/QUOTE]
you are totally right.
I seen it happen so many time. bad shop to balancing tires.
what they said^^
basically... the offset is the issue with the rears.... i ru nthe same size wheels but my offset in the rear is -55 yours look to be more like -45 so your wheel is sticking out and contacting the fender lip... bottom line is you definitely need to roll the fenders the inner fender lip can be rolled up and flattened or sliced off to give you more room that is your only solution... .stiffineng up the RR susp only will make the car handle like **** and be way tail happier than this car already is...
get the rears rolled & you should be fine...
ed G.
ed G.
