Spring vs. Rear Sway Bar
I am debating whether I should get the rear sway bar or the f-sport springs. I'll probably just get one of them now and get the other a little ways down the road. Which will make the biggest difference handling wise? I realise the springs will add the lowered look to it but I think I am okay with the height of the car right now. I am leaning towards the sway bar because it is much cheaper to do.
Well, I decided to go for the springs. We'll see how they turn out and if I still feel like it doesn't handle well enough I'll get the sway bar. I found a friend that will install the springs for me so that will save a lot in labor and I can probably just get both now.
Definitely get the rear sway bar while it's on sale from sewell. I just bought mine for $181 from lexus of pemberbroke, fl, and it was worth it. I installed it the other day, took like 30 min. Easy to install and my 350 corners noticeably better. I can take turns much faster with less body roll and the car just seems to point where i turn it.
just my $0.02...
just my $0.02...
just my $0.02...
just my $0.02...
Super easy to install. I backed the car up on ramps then waited for the exhaust to cool off. Took 6 bolts off (2-17mm & 4-12mm) removed the oem rear sway bar, then installed the new one. It requires a torque wrench, so I bought one from walmart for $25 then returned it 2 hours later.
Lou
"Why oh why didn't I rip off a good wrench!" you'll be saying, while the officer writes you up for too fast for conditions!
Just kidding!
cmp0626
15
10-20-10 11:15 PM
