OEM struts with aftermarket spriings?
you can use aftermarket springs with stock struts but usually a good idea to replace the struts at the same time, preferably with aftermarket struts. This is because if you are using lowering springs, they will wear out OEM struts much faster than aftermarket struts designed to take the abuse
