Suspension Upgrade
Suspension Upgrade
Hey guys, I've gotten for my IS350 the F-Sport front and rear sway bars and rear brace to go with my JIC Coilovers. Since I want to do all of this at one time, what else should I be considering for best handling.
Do any other braces contribute significantly to the handling. For what it's worth, I did feel the rear F-Sport brace made enough of a difference (in another car) to add it to the kit.
Unless you're tracking the car, on slicks, you're unlikely to find any measurable improvement from additional bracing.
These aren't the lightest wheels, but they are pretty light for a 3 piece rim. I'll be going to the 275 rear tire and then add custom spacers to fill out the wheel wells after the coilover installation.
No looking for the lowest drop, just about 1.5" lower in the front with the rear to match will be perfect and should allow good handling characteristics.
Any other parts I should be looking at?
Is anybody running the JIC Coilovers with the F-Sport bars?
Any thoughts on initial setup? Ride height? Damping settings?
Got a pretty good guy to do corner balancing, 1/2 tank of gas and me in the driver's seat, right?
(I guess real handling performance takes a back seat to "lip", "flush", "slammed", and so forth.)
Do you not already have the coilovers installed?
If you are installing the coilovers, swaybars and new brace at the same time the difference is going to be DRAMATIC. Have fun with it for awhile.
Good tires and good brakes will finish it off. Good pads will go a long way in the braking department, as will SS lines and fluid.
PM us if you need anything
This Lexus (18K mileage) splits time with my 08 Rubicon 2-door (9K), just built and also paid for, as my daily driver, and I've got a bit planned for the IS since the Jeep is mostly finished.
Very good suggestion about the stainless steel brake lines, I hadn't even considered that. Yep, been rolling on the stock suspension since purchased new, upgrade city now! Briefly looked at big brake kits, down the road for sure, but didn't even think lines. Thanks a bunch.
I don't know if that's entirely true, I'll be interested in seeing if SS lines give any improvement to brake feel.
I wasn't "mocking" anything, we just have a lot more posts here about "show" than we do about "go", which is entirely understandable.
They might improve the feel of the pedal if the stock lines are just rubber.
They won't actually stop the car any better or faster though... and I'd definitely count them as a "show" mod not a "go" mod because of that.
They look nice though.
Ya Ya.
Let me speak to you about show and go. LOL
Set your JIC's all the way to stiff (all four corners)
Your sways are going to help alot.
Get the SS lines, and some RAF 650 brake fluid, and some High Heat pads, for heavy use.
The JIC's are a tad bit soft (For me at least) but they will defiantly do the job, however if you really want to take turns hard, you will need a stiffer spring on that coil.
After you get used to the coils on stiff, you can slightly adjust the rear damper, to allow for rear weight distribution. So you can move it to 5 clicks maybe, depends on how you feel it.
One last thing, get the fsport upgrade (full) underBrace, that will stiffen the chassis more, I would recommend that only for track day driving, as its so low.
Tech Info Resource
I seriously doubt stainless brake lines will improve feel. Most manufacturers are using Kevlar braiding on their brake lines these days, so all you really get with braided stainless is more weight and a more frequent inspection interval. Oh, and cut fingers when a wire breaks and you find it with your hand while inspecting.
2IS OG
^It's my understanding (from brake engineers who have examined my OEM brake system) that Lexus OEM brake lines are braided with polyester. My Goodridge lines are an aramid fiber-stainless blended weave over PTFE (Teflon) hose, and they're guaranteed for the life of the vehicle.
Javier
Javier
