front lower control arm bushings question
do i have to completely remove the front lower control arm to replace the bushings? or is there a better way to do it?
how bout the front upper control arm? have to take that out too? any one have any links or manual for a r&r for a 1993 sc400 with torque specs. please let me know. help would be nice.
![](http://i8.photobucket.com/albums/a20/tidalwavetiburon/Suspension.jpg)
Oh yeah I almost forgot, you will need to get an alignment and to remove the upper control arm bolt you will have to remove the washer tank. Its really easy, if need any help or have any question let me know I just did this job and it rather easy.
Mine had 12 years of rust and I didnt have a single issue what so ever. I sprayed PB Blaster 3 straight days before doing the job and just used my breaker bar and all was good.
I wish. Check for my thread in this forum from the last week or two; my rear bolt on the driver's side was rusted in so hard that I had to grind it out. Turned a three hour project into a four day project.
Now the rear end links...............those KICKED my *** I had to grind those SOB's off. Then to make matters worse my fuel filter replacement which should have taken about an hour took me....well I'm still working on it lol.
I need help how to remove the upper control arms where the ball joint is the bolt is hard and I need to know what kind of tools will I need
