H&R vs. Eibach Springs - Comparative Review
I have history and experience with both of these springs on my wife's IS250 awd and thought I would write a quick review for others research purposes.
Brief intro, my wife had H&R Springs on her IS250awd and wasn't happy w/ the ride quality. Even I had to admit, it was pretty rough. Got her onto some Eibach 250's and ride quality improved much. She's happy.
From my driving of the vehical, here are my impressions of the two springs:
Ride Quality: Eibach wins. I'm sure it has to do w/ the progressive spring rate. H&R's are without a doubt a more sporty, stiffer ride. Eibach's are softer and made the car feel almost like stock again comparred to the H&R's.
On the flip side though, the car didn't handle quite as tight as when H&R's were on it. Cornering wasn't as precisce and braking felt like more effort had to be put into it to get the car to stop
I wouldn't say sloppy feeling, but compared to the H&R's they were 'looser' feeling. But thats what you get in terms of trade off for a softer ride, you get softer everything.
Drop Looks: H&R wins. Though the H&R and Eibach's rear drop of the car looked almost identical, it was the fronts where the H&R's were more even with the rear. Eibach's raised the front just a bit, perhaps 1/4 to 3/8th's of an inch.
Eibach's = softer, more comfortable, slightly higher front (very slight^^)
H&R's = firmer/sporty, very even drop (probably the best drop you can get on springs)
**EDIT** I also wanted to throw this out there. H&R's comfort level feel better on my IS350 vs. my wifes' IS250AWD. I'm guessing its due to the strut length being different on the two cars suspesion. I have to admit, it was pretty rough riding in my wife's IS250AWD, whereas my IS350 feel firm, but not overly harsh like her's did. Anyway, just my thoughts on the same spring on an AWD vs. RWD.
Yes, they are 'progressive' but they do not function the same way Eibach's do. When H&R's are loaded into the cars suspension and compressed, all of those 'progressive' coil winds essentiall become dead coils. They are compressed to the point that they are touching eachother, fully dead, they have no function. I think this is simply designed so the spring doesn't uncoil when the car raises up.
Eibach's on the other hand acutally make use of the softer portion of the coil, obsorbing samller road imperfections yielding a more comfortable ride.
Good writeup on the springs, thanks.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I'll add a few notes about my recent (May) installation of Eibach 350's on my IS350 which originally had factory sport suspension w/ Eibach drop of 1.0"/0.8":
. Ride is generally good, firmer than stock sport suspension. Some low speed harshness with 19's is slightly reduced with the Eibachs. Normal freeway conditions give a good ride.
. Handling is slightly improved with less body roll and improved high speed stability.
. Big high speed bumps (75mph+), I can feel the shocks strain a bit to control rebound causing more up movement than stock suspension.
. Speed bumps do require a bit more slowing for comfort.
. Car doesn't looks lowered/slammed, it looks nearly perfect with 19's, like it should have come, IMO.
. Conclusion, money well spent, nice ride/handling combo with much improved looks. I have no interest in going lower. The car still rides and handles like a Lexus.
Good write up and I have sat in a car with Eibach 250 and it is definitely very smooth. Funny thing is though, with H&R on my IS250, my mom thinks the ride quality is smoother than it was when we first got it. She doesn't even know I got H&R...just told her took some time to settle in. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
The harshness could be due to it being AWD and having a different shock assembly?
No clunking with Eibach 350's on my IS350. Eibach 350's and f-sport springs are closest to factory ride w/minimal drop. But doesn't Tien make a conservative version of it's springs too?
[QUOTE=stonefan52;4600189]Good write up and I have sat in a car with Eibach 250 and it is definitely very smooth. Funny thing is though, with H&R on my IS250, my mom thinks the ride quality is smoother than it was when we first got it. She doesn't even know I got H&R...just told her took some time to settle in. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
The harshness could be due to it being AWD and having a different shock assembly?[/QUOTE]
Yes, must be because I have H&R's on my IS350 (my wife drives IS250awd) and its not as harsh on my IS. I'm also guessing due to the different struts.
That's a good test of the ride factor
, I did the same with the Eibach 350's (without mentioning a change was made to springs).
1. A few days after the installation I picked up my wife from the airport and drove her home, no comments on the ride even on the bumpy route home.
2. Drove my mother around on the country roads near her house on the weekend after the installation, no comments on the ride.
Good review.
yayy can't wait till i install my H&R springs this weekend, should be getting them in the mail any day now. Thanks for the write up. pretty awesome.
i wanted the best drop springs could get me, don't have the $$$ for coils, and since i find most people here saying that the HKS hi power is loud and obnoxious, but i find it perfect in loudness and tone. i'll assume when people say the H&R drop is a bit bumpier than eibach, that its not very bumpy at all hah.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
That's mainly due to the struts not being able to rebound quick enough due to them being put to 'work' in a 'range' they aren't used to. Lowering the OEM struts put's them under more stress and they don't work as well as when at stock ride height...
But like I said, for moderate roads and slight things here and there, H&R's are great... but you'll see your first pot hole or big bump at high speeds in the road... its gonna be *!!BAM!!*
Having said all that, I still love em' and wouldn't trade to any other spring. But when these struts blow, and they will, I'm going to go to coilovers for adjustable dampening & precise ride height.
thanks alot for the write up man, i have a quesiton, i got mine used, and i don't have any rubber sleeves to keep the coils from rubbing together when compressed and making that *bam*. Do they come w/ a rubber sleeve brand new?
