tien HA's to C8 coilovers should I
i've been thinking bout these coilovers but somthing isn't right 600.00. for a set but my current coilovers have pillow and ballmounts and are nice and stiff but i want to try soming new. here the info on this coilover
CORNER EIGHT SPORT SUSPENSIONS (C8 Sport) FOR YOUR CAR Corner Eight Sport Suspensions allow you to improve the steering responsiveness and handling of your car while maintaining OEM ride quality through height and 20-way dampening adjustability. Anodized Billet Aluminum Mounts and Lower Brackets ensure Wear and Corrosion Resistance Adjustable Spring Perch for Height Adjustment Triple Perch Locking Design (2 for spring height, 1 for body height) Additional Height Adjustment Through Adjustable Shock Body Length Height Marks on Shock Body for Consistent Height Adjustments 20-way Adjustable Dampening Pillowball Upper Mounts available on certain applications Rubber Dust Boots Standard 1 Year Limited Manufacturer Warranty hmmm makes me say u get what u pay 4... but what if these were better thann tiens or stances for 1/2 of the price..
more info f and spring rates
14.0 front/8.0 rear (kg/mm)782 front/447 rear (lb/in)
what do u think
what do u think
with 14/8 it will be more "sporty" then stiff compared to stock.
i wouldnt buy them. they look like some cheap chinese ****.
they dont have pillow ball mounts. the rubber will wear out quickly most likely. email the manufacturer and act what they use as an insulator pad between the spring and the upper and lower spring perches.
my buddy bought a set of e-motoring coilovers for his s14. they were 500 bucks. they were ridiculously stiff even though it had soft springs in it....implying improper valving. my stances on stiff felt better then those on softer settings. those coilovers blew out after 2 months for the rears and 2.5 for the fronts.
this sounds like one of those deal.
Cam seriously if you want some coilovers lmk. i can help you get some stances. yes they are more money but they are worth it and the customer service you get from stance very good.
you have my number :-)
btw u still got that kevlar hood?
