Oem rotor replacement
Nobody has mentioned BAER!! i have the Baer decelaroter its x drilled & slotted with EBC pads and they are the sickest set next to actual big brake set up. Honestly Rotors 2 best on the market BREMBO & BAER! Rotera are good but nothing like BREMBO or BAER. you can go to autoanything.com and get yourself BAER decelarotors for $208 front pair
that seems like crazy over kill unless you are racing your car at the track every weekend
I thought the ZR1 has like a 6pot front and 4 pot Rear
I put Brembo rotors and Akebono Proact pads on my 94 GS300, and they were great. Also put ATE PremiumOne slotted rotors on my 99 GS400. All were bought from Tire rack. Rotors were around $42 each + $58 for pads. Way cheaper than the stealership...........
can't imagine that. My LS brakes is already good enough. If I brake hard, the car stops and I lunge forward out of my seat...and I'm the driver. I always make sure I leave enough room for the SUV following me from behind
It might be overkill, but I bet he has a 1200whp monster.
ArmyofOne
Wheels, Tires & Brakes Forum
04-04-09 03:00 PM
