Brake changes from 1995 model and up?
Was getting a quote from one of the vendors for rotors/pads and he got back to me with this:
"Hawk only lists pads for the '96+ Sc300, did anything change form '95 to '96?
The rotors are listed as onlt rhw late model 99-00 sc300 for powerslot and the brembos only list sc400."
As far as I knew, SC300/SC400 used the same components (rotors, pads, brake lines) throughout its lifespan (92-00)... anyone know different?
Hm checkout this thread: https://www.clublexus.com/forums/sus...e-fitment.html
I'm not sure if the difference is in the material or size.
sc400 brakes = supra na
sc300 brakes = a bit smaller then sc400
I dont know the exact year but eventually the sc300 adopted the supra na/ sc400 brakes.
Also i wouldnt bother buying those brake pads atleast not for sc400 brakes. Upgrade to ls400/supra tt then buy pads otherwise you are just wasting money.
Generally, the price changes from year to year would indicate a change in the part. Whether it be the size or characteristics of it I am unsure.
Definitely, the 92-98 sc300 rotors share the same size. The 99-00 applications won't apply to pre-99 as they would be too big.
Definitely, the 92-98 sc300 pads are also the same size. According to a TSB back in 95, the pre-96 pads were packaged with shim/fitting kits. The 96+ pads came with only pads and the option of buying the shim/fitting kits separately. This difference is the reason why 96-00 pads are cheaper than 92-95 pads and what the Hawk application may be indicating.
Hope this clears the air a bit.
MAM423
SC400 / 300 Classifieds
02-06-10 06:10 PM
kmn5
Suspension and Brakes
22
06-06-03 04:21 PM
