how to remove the rear rotor?
I removed the caliper but the rotor wont come off.
The manual says to "return the shoe adjuster until the wheel turns freely" if the rotor does not come.
I do not know where this shoe adjuster is, don't see anything like that.
I hate the "shoe adjuster". The spring and pin popped out one time and what a nightmare it's been. I lost the pin and had to get one from Toyota. Then I had to install everything back together and get the adjuster gear just right after a few test spins. I'm still convinced that the e-brake shoe is slightly rubbing the inside of one of my rotors causing vibration at higher speeds.
