Change in Specs for Front F-Sport Sway Bar??
Old 06-28-09, 08:25 AM
blockerm
blockerm's Avatar
Default Change in Specs for Front F-Sport Sway Bar??
New to the forum but it has already been very helpful in making some decisions. I searched through the other posts and did not find an answer so here goes. Other threads indicated that the F-sport front sway bar is only 6% stiffer than stock. Early press releases from Toyota aligned with that (Sept. 08). Now on Fsport.com, the stats indicate that the front F-sport sway bar is 42.8% stiffer...not as trivial and easy to blow off as 6%. Have others seen this or am I missing something here?
http://www.fsport.com/assets/pdf/F-Sport_Brochure.pdf
Old 06-28-09, 04:16 PM
Kurtz
Kurtz's Avatar
F-sport.com said 6% as well until very recently.
Now it says 6% for the rear 250 RWD bar (where it previously said 42.8%)
I suspect somebody typoed when they updated the numbers to add the other vehicles they recently added to that page.
Old 06-28-09, 05:22 PM
edwin907
edwin907's Avatar
What about the IS350C bars?
I presume they aren't interchangeable with the IS350 bars?
I'm about to start installing my JIC coilovers, F-Sport sway bars, and F-Sport chassis brace on my IS350, wish me luck!
Old 06-28-09, 06:03 PM
2007is350
2007is350's Avatar
cool good luck with the install , update on how it goes with the install and what the difference in the cornering vs stock
Old 07-09-09, 01:34 PM
is350wh
is350wh's Avatar
I just bought the front and rear sways. I bought the "2009MY" set, which is apparently a different set. There are two separate part numbers:
PTR02-53082
PTR02-53094 (this one says "2009MY")
>Maybe they tightened up the front more with the 2009MY sway bar set - or -
>Maybe the "stock" front sway for the 2009 IS350 is softer than previous model years and so the F-Sport sway inherently tightens it up a lot more.
But, the descriptions for both parts are identical (below), so I don't see how the 2009MY set could be any tighter.
PTR02-53082
Material - front 4130 chrome moly CNC steel tubing, forged end bars | rear high strength CNC steel bar, forged bar ends
Size - front 28.6 mm diameter, 4.8 mm wall thickness | rear 19 mm diameter solid bar
Bushings - special high duromter dry lube impregnated rubber bushings, 75 durometer hardness
Spring Rate - front 141.3 N/mm | rear 81 N/mm
noycy003
CT 200h Model (2011-2017)
20
05-01-19 01:40 PM
CalvinGSH
Suspension
07-31-15 08:19 PM
JdSwiper
Suspension and Brakes
07-22-14 05:07 AM
Quick Reply: Change in Specs for Front F-Sport Sway Bar??
