F-Sport Brakes vs. IS350 Brakes vs. Others
Tech Info Resource
Most likely they won't unless you do a lot of top speed runs and brake really hard after them. Very few people need to be concerned about cracking for street driving.
LOL, fsport brakes wont crack under street driving!
I have USED and Abused these rotors for a long time now.
Track Use and moderate braking mountain roads (http://www.youtube.com/watch?v=qm1ufEJmqhQ)
I'm surprised those rotors showed cracks, after their first track day.
That is really disappointing.
I think those pads, might have been to aggressive for that rotor?
Oh well, as long as they didn't fall apart!
Tech Info Resource
Oh well, as long as they didn't fall apart!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
What about the weight difference between the three? The 250's are the smaller of the rotors but do they weigh less than the F-sport ones? With the aluminum hats and cross drilled rotors they should be considerably lighter than the 350's rotors and maybe even weigh in less than the 250's. If this is the case, which it most likely is, then the loss of un-sprung weigh from the front suspension would help with braking, steering response, and even exceleration, to a point anyway. Just something else to consider.
Confirm that the F-Sport Rotor will not crack with Street Drive. 1-2 Laps of track also can.
Via the Website they say that come with "braided stainless steel brake line" but after order and received the package, they are not. I had contact the Manu (Stop-Tech) and they confirm that no "braided stainless steel brake line" come with the package. They can use with OEM brake line.
Only one problem was a noise of their Pad when using in street drive. Too loud.
