F-Sport Brakes vs. IS350 Brakes vs. Others
#49
#50
Got a few question/problems:
1) I am having rattling in my front passenger brake. It's a light rattling over uneven surfaces. I did some research and seems like some aftermarket pads rattle. Anyone has/had this problem? I have Akebono front pads. I didn't have this rattling before doing the swap and I'm sure nothing is loose on the caliper because I double checked the torque specs on the bolts holding the calipers to the knuckle. I am using the OEM pin and metal clip for the front as well.
2) Is this normal? Seems like the rear pad doesn't cover the entire rear rotor (Stoptech). I went to autozone thinking the IS350 pads were bigger than the IS250 but they said it's the same part. I am reusing my rear IS250 pads. Are there bigger aftermarket rear brake pads?
![Name: E56D0F68-450F-4F5D-A8E2-4CD5099EBBC9_zpsj5dqofkg.jpg
Size: 90.9 KB](https://www.clublexus.com/forums/attachments/suspension-and-brakes/414279d1501200234-f-sport-brakes-vs-is350-brakes-vs-others-e56d0f68-450f-4f5d-a8e2-4cd5099ebbc9_zpsj5dqofkg.jpg)
![Name: D880EA12-AEE8-40C3-BAB3-8CCC4CD3EEBC_zpse9wcljgs.jpg
Size: 117.4 KB](https://www.clublexus.com/forums/attachments/suspension-and-brakes/414280d1501200234-f-sport-brakes-vs-is350-brakes-vs-others-d880ea12-aee8-40c3-bab3-8ccc4cd3eebc_zpse9wcljgs.jpg)
RSXiMUS
IS F (2008-2014)
05-27-22 09:55 PM
